Innovative Diesel Tune - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-02-2014, 03:23 PM Thread Starter
08StormTrooper's Avatar
just got my Xtreme Race tune in for my 08 6.4 on the SCT9625OR and it's fantastic. the question I have is about the shifting, I know it will do a relearn after about 100 miles but should the downshifting also be a little rough too? I've notice the subtle jerk when coming to a stop. Also, I don't want hell about it, but occasionally on open track Fridays I throw this thing on the track against my buddy's trucks and their little imports, will it be just as rough regardless of relearn on the track? because before I was running the extreme canned tune that came with my SCT and it shifted smooth even on the track. just askin from someone's experience I guess. thanks.
'08 Ford F-350 Super Duty
6.4L V8 Turbo Diesel
DPF/CAT delete
EGR delete
AFE Stage II R5
H&S XRT Pro
AFE 4" Turbo back exhaust
AFE Turbo Intercooler
Strokin' since the start.
08StormTrooper is offline
post #2 of 8 Old 04-03-2014, 06:45 PM
B585Ford's Avatar
I cant help ya cause I got a gear jammed but I will give ya a free bump.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #3 of 8 Old 04-03-2014, 06:57 PM
gone6.0's Avatar
Quoted: 12 Post(s)
my 6.0 does in tow haul. It will sometimes squall the tires down shifting, that is while braking. cant run tow haul when roads are wet.
2004 F250, SCSB, APR studs, Banks intercooler, Edge Insight, SCT with tune from Eric, atlas 40, deleted, 2" leveling kit, coolant filter, 6.4 banjo bolts with blue spring, Harpooned, Nathan K5LA. Nations 190 amp alt.
Twin Viair 480C's. BOSS superduty 8' poly plow.
gone6.0 is offline
post #4 of 8 Old 04-03-2014, 07:15 PM
crash&burn's Avatar
Mines the same way
Shawn
2004 CC F350 - 4-5" exhaust no cat - CTS Insight with turbo timer and Egt's - EGR Delete - K&N - Coolant Filter
SCT with Custom Tunes - MTW MadMax - 190/Stock - PTP Solenoid - Blue Spring - A few mystery switches
crash&burn is offline
post #5 of 8 Old 04-04-2014, 03:41 AM
No one is going to give you he'll about running your truck on the track. People tend to jump on people for street racing!!
seafordguy is offline
post #6 of 8 Old 04-04-2014, 04:33 AM
strokinginstyle6.4's Avatar
If you perform the trans relearn procedure right after you program it that should speed things up with the relearn process and odd shiffting behavior. However i believe u rather have a firm shift anywasys vs a softer on due to slippage in your tranny.
strokinginstyle6.4 is offline
post #7 of 8 Old 04-04-2014, 04:39 AM
STOCK TCM
1. From a stop, accelerate the vehicle to 60 mph at approximately 1/2 throttle.*DO THIS three times.
2. From a stop, accelerate the vehicle to 60 mph at wide open throttle.*DO THIS three times.
1. From a stop, accelerate the vehicle to 55-60 mph at approximately 1/4 throttle.*DO THIS TWICE.
2. From a stop, accelerate the vehicle to 65-70 mph at approximately 1/2 throttle.*DO THIS TWICE.
3. From a stop, accelerate the vehicle to 70 mph at approximately 3/4 throttle.*DO THIS TWICE.
4. From a 40 mph roll, press the accelerator to the floorboard quickly (forcing the truck to downshift) and accelerate to around 75 mph.
5. From a stop, acclerate to 75 mph at wide open throttle (press the accelator to the floor immediately).*DO THIS 2-3 TIMES.*
post #8 of 8 Old 04-04-2014, 05:29 AM
Sounds to me like your TQ isn't unlocking when it should during a down shift. I had that problem with my 5.9 (Goerend Race Tranny).
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
