Passing emmissions in Mass - Ford Powerstroke Diesel Forum
post #1 of 15 Old 04-02-2014, 02:39 AM Thread Starter
arcticatman's Avatar
Just wondering if anyone has an answer to pass with a deleted truck in MA? I have a friend who can pass with his spartan but my H&S wont pass, Both of us have egr deletes and the Straight pipe exhaust. Im looking to get another 6.4 and would like to stick H&S due to transmission tuning but may jump to spartan if its impossible to pass without returning to stock every year. Any input or ideas are appricated.
Thanks Cody
1997 350 7.3 dump truck/Work Truck
2008 350 Reg Cab
H an S 300 tune
Flo pro egr delete with elbow
Flo pro 5 inch turbo back
s an b intake
Cat ELC
Ready Lift 3.5 sst kit
20inch Platinum wheels
Much more to come!
arcticatman is offline
post #2 of 15 Old 04-02-2014, 03:09 AM
B585Ford's Avatar
IIRC MA does a readyness check. Is that what you are failing?
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #3 of 15 Old 04-02-2014, 03:12 AM Thread Starter
I couldnt tell you it must be my friend does inspections and when you have to plug into obd2 it just automaticly prints out a fail. So id assume it is the readyness check and pulls up the missing sensors?
2008 350 Reg Cab
H an S 300 tune
s an b intake
Cat ELC
Much more to come!
post #4 of 15 Old 04-02-2014, 08:45 AM
I couldn't pass in WI with my H&S MM - EGR valve would not "Ready" itself for ODII test - Failed the first time. I loaded the lowest power level and drove around for a couple days. I borrowed a friends ODII scanner and the EGR valve would't change it's state - despite it cycling on low power. H&S must do something that blocks it's ability to change state, unfortunately.
I had to revert back to stock and re-install emissions to pass.
-Mike
2010 F250 CCSB Lariat FX4
MikeSherman is offline
post #5 of 15 Old 04-02-2014, 09:15 AM
B585Ford's Avatar
OP,
I would contact GH and see if they can make a tune that would "ready" the EGR before I gave up on H&S.
B585Ford is offline
post #6 of 15 Old 04-02-2014, 09:16 AM
B585Ford's Avatar
-Mike
Did you try the "Easy" tunes?
B585Ford is offline
post #7 of 15 Old 04-02-2014, 09:17 AM
...then share the tune with the rest of us poor emission regulated saps!!
-Mike
post #8 of 15 Old 04-02-2014, 09:18 AM
Yes, I was on easy tunes, no power, no luck.
-Mike
post #9 of 15 Old 04-02-2014, 09:21 AM
B585Ford's Avatar
-Mike
Unfortunately, since that was on the "Easy" tunes and those tunes do use the EGR, I doubt Matt could do anything....it's worth a try but my guess is it something within the programmer that can't be changed...like you said.
B585Ford is offline
post #10 of 15 Old 04-02-2014, 10:03 AM Thread Starter
How does spartan make it pass when H&S falls short?
Sent from AutoGuide.com App
2008 350 Reg Cab
H an S 300 tune
s an b intake
Cat ELC
Much more to come!
