CEL P1633 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-01-2014, 09:19 PM Thread Starter
CEL P1633
I have a CEL that has been on in my truck, everything seems to run fine, no noticable issue. The code is P1633, keep alive voltage too low. I have no idea where to start, asked at autozone, they had no idea, my mech had no idea and I asked a Ford mech he was even unsure. anyone have this happen to them?
It started after my mini maxx was put in my truck, no sure if that changes anything, the light on my dash drives me crazy though. Thank You for any help
mtfd49 is offline
post #2 of 3 Old 04-03-2014, 02:25 AM
B585Ford's Avatar
Had you been driving right before you installed the MM? Did you clear the code and see if it would come back?
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #3 of 3 Old 04-03-2014, 05:40 PM
I'll share something I looked up on my shop computer:
Tests/Procedures:
1. This code suggests power to the TCM has been interrupted. Since this started with a reprogram, a fuse likely blew during the programming process.
2. Check fuse 37 in the battery junction box under the hood. It is a 10 amp fuse. If it is blown, replace the fuse and retest.
3. If the fuse is not blown, the modules should be programmed again using a factory or equivalent scan tool.
That's what it says to do when the problem occurs following a reflash.
2010 F250 Harley Davidson. H&S Mini Maxx Race, MCC, 5" down pipe back SS straight pipe, S&B intake, Snow Performance water/meth, FASS fuel pump, Sinister EGR delete, elbow & CAC pipe, Sinister filter housing caps, Bak Industries F1 tonneau, 295/65/20 Nitto Trail Grapplers, Detroit Truetrac (in box for now), lots of lights!
highup0 is offline
