Livewire SCT 5015 C with delete DONE :( - Ford Powerstroke Diesel Forum
post #1 of 32 Old 03-29-2014, 05:07 PM Thread Starter
hoofdoctor's Avatar
2008 6.4 Dually Extened Cab Long Box with Tow Boss and 4:30 gear ratio
Well I did the full delete yesterday. SCT Livewire 5015C, S&B CAI, Sinister inercooler pipe, diamond eye exhaust pipe.
The good...... this will be short. The guy's that did the work were great!
The bad........ Out of 10 custom tunes installed the only tune that works is the B4 or number 4 tune. The tuner came with zero paper work so I don't even know what the horsepower is on this tune but what I do know is I want a bit less! The truck turned into a SCAREY MONSTER! If I was into drag raceing I'd have some use for it. It would most certainly ad up some kills! I tried to de-tune the beast one step at a time, first down to tune B3 and after loading the tune I got a wrench "with no code" and the truck turned into a pooch! A total slug! So I thought I'd try the next tune down, B2. Well after multiple NO STARTS, and 2 hours of trying to load B2 I simply gave up, for now! I then loaded B4 back on and did some more testing. The shifting isn't smooth like it was prior to the deletes so that needs work or learning , if it will ever learn??? One note: IT IS EXTREMELY DIFFICULT TO STAY OFF THE PEDAL WITH THE B4 TUNE....HOLY MONSTER BAT MAN.....
The little good that may have come out of this...........
My liar meter showed 15.6 MPG when I pulled into the shop. When I left I filled the tank and on a 159 mile trip home the liar meter was showing 25.6 MPG. I stopped and refilled the tank and on paper I'm getting 15.9 so the overhead is waaaaay off. The only other paper MPG I did was on a 2000 mile trip where I was getting high 10's. I think there is room for improvement in the MPG department and hope that "if" I get the lower tunes to work that perhaps B2 or B3 with a little less HP will save a little more on the fuel. My main purpose for the deletes other than letting this truck live longer by dumping the EGR and DPF is the MPG.
Anyone that has any 5015 C experiance, please share!
I'll update after Monday when we call in and beotch!
hoofdoctor is offline
post #2 of 32 Old 03-29-2014, 05:18 PM Thread Starter
hoofdoctor's Avatar
A couple things I wanted to ad
The truck has 129,000 miles on her. The inercooler had the typical black oily mess in it. The EGR and DPF were extremely clean in my opinion! I hope I made the right move doing these deletes!!!
post #3 of 32 Old 03-30-2014, 09:05 AM
lildevil02's Avatar
Sounds like the error is in the tuning..... Is the tuner showing an error code when trying to load in a tune? If so what is it?
lildevil02 is offline
post #4 of 32 Old 03-30-2014, 11:40 AM Thread Starter
hoofdoctor's Avatar
I agree.........No codes. Wrench on the dash. Shut it down and it won't restart. Then need to reprogram back to stock and start over. Never did get tune 2 or 3 to load. Running on 4 for the time being! Shift is rough on 4. Don't care for that tune on the tranny. Maybe can adjust it.
post #5 of 32 Old 03-31-2014, 05:50 PM
B585Ford's Avatar
If you keep off of the skinny, you will probably get better mileage out of the higher HP tunes cause they run more timing.
Did you buy this tuner used? I would contact SCT about your experiences. I wonder if some of the tunes are corrupted?
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #6 of 32 Old 03-31-2014, 06:30 PM
lildevil02's Avatar
Have you checked you DTC on the tuner? What does it say when you try to load in another tune? Whats the exact error you get?
post #7 of 32 Old 03-31-2014, 06:52 PM Thread Starter
hoofdoctor's Avatar
The tuner is new. I'm not heavy in the foot by any means! Made contact today with the tune provider but didn't have time to try a fix yet. We had a family matter to take care of. Will try tomorrow. I was told that perhaps the file was corrupt when it was loaded.
post #8 of 32 Old 03-31-2014, 07:00 PM Thread Starter
hoofdoctor's Avatar
I have checked the DTC. No error codes shown. I get a wrench on the "dash" display!
post #9 of 32 Old 03-31-2014, 07:13 PM
lildevil02's Avatar
What does the tuner say when you try to load in tune 2 or 3
post #10 of 32 Old 04-01-2014, 04:04 AM Thread Starter
hoofdoctor's Avatar
Something like "tune loaded successfully".......... Turn the key and nothing. Won't turn over. """NO CODES NO ERRORS"""" Just the wrench "on the dash computor screen". I tried several times and it takes about 45 minutes to go back to stock and reload the tune.
