dpf & egr delete tunes and help - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 18 Old 03-29-2014, 04:40 PM Thread Starter
Ive decided to delete my dpf & egr after reading all the threads. Im currently running on my 2008 6.4 a afe cai, magnaflow 4" cat back exhaust and a sct livewire 9625 tuner. I recently started throwing a p2002 cel. Im basically looking to accomplish better mpgs with reliablity and the added power is a plus. I should also add that i tow on occasion a 32' 5th wheel trailer weighting in at around 13k loaded roughly.
My question is will the sct livewire support dpf and egr delete tunes? Also if so what are the best tunes in your option for what im trying to accomplish and where can i get them?
All input is greatly appreciated. Thanks in advance...
08projectpowerstroke is offline
post #2 of 18 Old 03-29-2014, 05:22 PM
If it's the 9625OR model yes it can delete the dpf and EGR. As for custom tunes it's really a case by case basis some people like one but not the other. But a few to look into would be gear head or IDP. If your tuner is not delete capable you would have to find one that is first. The sct 3015R or 9625or are around 800-1000 used on eBay or the forum.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #3 of 18 Old 03-29-2014, 05:30 PM Thread Starter
How can i tell if my tuner is the 9625or? it says mine is a 9625 extreme
post #4 of 18 Old 03-29-2014, 06:15 PM
That I don't know, maybe someone who has one will be able to tell you how to find out. Or you could call sct
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #5 of 18 Old 03-29-2014, 06:35 PM Thread Starter
now that im starting to dig deeper im not even sure if i have the 9623 or the 9625. I have the extreme tune on mine but from what i read so did the 9623. Ooo boy...
Is there a way to tell by the serial number lw08290700a5f?
post #6 of 18 Old 03-30-2014, 10:00 AM
lildevil02's Avatar
Contact SCT tech support, give them the serial number & they'll be able to tell you for sure. All SCT tuners that were originally DPF off had OR at the end of the model numbers.
lildevil02 is offline
The Following User Says Thank You to lildevil02 For This Useful Post:
08projectpowerstroke (03-30-2014)
post #7 of 18 Old 03-30-2014, 11:28 AM Thread Starter
i put an email in and waiting for a response. what about tunes? any ideas?
post #8 of 18 Old 03-30-2014, 12:18 PM
lildevil02's Avatar
If it's an OR tuner then it will work. If not then it will not work.
post #9 of 18 Old 04-01-2014, 10:34 AM Thread Starter
Still no response from sct and now starting to get a loud ticking sound after tunning to the performance settng. Sounds like a valve is going out. At 2200 rpms is ticking pretty loud.
post #10 of 18 Old 04-01-2014, 11:12 PM
SixPoint4's Avatar
The valve guides on the 6.4 heads are pretty embarrasing... Im surprised ford even allowed prodution of these heads. very likely that a valve or guide is going out with the added power. I personally would not run a hot tune on a truck with the dpf on and activated. It's probably in ReGen more than it should be. check this video out
https://www.youtube.com/watch?v=XMRYrUqJ_X4#t=301
2008 f250 CC SB, Fox 6" Lift 37" Tires, Stock Motor (For Now)...
SixPoint4 is offline
