Issue maybe - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-28-2014, 10:41 AM Thread Starter
Issue maybe
So I noticed that after I drive my truck, park and then idle there is something that is kicking on and off about every 20-30 seconds. The rpms don't change but the fuel rail pressure changes from 5000 when off and to 5500 when on I'm assuming it's off and on. Also the tone of the idle changes during the off and on. Not sure if it's the EGR valve or what else it could be? I have not installed the EGR delete listed in my sig yet just not enough time. I run the spartan 250EL tune 5" exhaust and S&B intake. No codes come up on the dash daq. Any ideas as to what this could be and if it's a cause for concern? Truck runs great otherwise.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #2 of 11 Old 03-28-2014, 02:18 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
I don't have an EGR and mine doesn't do that. Not saying it is def the EGR, just that I haven't noticed it. I also idle at about 5600 (in pretty sure) but I'm on the 300 tune
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #3 of 11 Old 03-28-2014, 02:42 PM Thread Starter
Thanks aggie, I called a buddy of mine (owns several 6.4's) and he's confident that it's just the EGR. I'd just never noticed it untill a few days ago and wanted to ask and make sure it wasn't anything else. Can't wait for a day off so I can get this EGR delete put in.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #4 of 11 Old 03-28-2014, 03:49 PM
Kris, just did my EGR delete using Sinister's kit. Allow plenty of time and don't get in a hurry. My one tip would be this:
After you take out the battery tray and degas bottle, check the upper bolt that connects the lower EGR cooler to the exhaust. Chances are it is really tight and will round the bolt head off when you try to remove it. Soak it good with PB blaster, soak it again, and soak it again. Let it soak while you do the rest of the EGR removal. When I did mine, I wasted 3 hours getting this one bolt out. In the end I had to take a dremel and grind the head of the bolt off.
Good luck!
mhutch2 is offline
post #5 of 11 Old 03-28-2014, 03:59 PM Thread Starter
Thanks for the heads up on that. Just waiting until I have enough time set aside to do the install and a friend just incase on need to run and get something for the process and don't leave myself stranded.
2008 CCSB Lariat
Spartan 250EL
Flo-Pro 5" DP back
S&B Intake
Sinister EGR Delete
Kris 6.4 is offline
post #6 of 11 Old 03-29-2014, 07:15 AM
08stroker250's Avatar
The 250 tune allows the valve to cycle at idle. That's what you're noticing.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #7 of 11 Old 04-01-2014, 02:21 AM
B585Ford's Avatar
Could he change to the 310 to confirm it?
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #8 of 11 Old 04-01-2014, 05:39 AM
^^^^^WHS. If it bothers you, is switch to one of the higher tunes that disables the egr. Personally, if it was me I would want to know on these trucks in case it could be an issue. FWIW my egr is still intact(for the moment) but I run the negr tunes and don't have this
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #9 of 11 Old 04-01-2014, 09:15 AM
B585Ford's Avatar
I know Spartan cycles the EGR to try to keep them from building up and sticking....just not sure if the race tunes completely shut if off...hence my question to Jeff.
B585Ford is offline
post #10 of 11 Old 04-01-2014, 09:47 AM
I believe it is completely shut off on 275 and higher. Maybe Jeff will chime back in if I'm wrong
2010 F250 CCSB
06psd6.0 is offline
