Gear question - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-25-2014, 05:46 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
Gear question
2009 F250 4x4
7" Icon lift
37/13.50 mud grapplers
H&S tuned/deleted. 5" exhaust.
So its the first time ive towed since i put the bigger lift on. I knew it would be different, because daily driving i can tell the heaviness of the tires/wheels.
Anyway i towed a buddies 7.3L excursion home about 100 miles. I have a 24ft gooseneck that probably weighs around 4000lbs or so, i dont know.
Anyway it pulled great and i ran 70-80mph most of the way. My boost really spikes up though, more so then before (obviously tire weight i know), but seems like even towing at lower speeds on the two lane roads id see 25-33lbs of boost. Seems like a lot. Would a regear eventually be something to look into. And if so which gears to swap with. Theres a ton of opinions on the topic that ive already read. i came from gassers and 4.56 was kind of the sweet spot for 37s.
Id like some real world experience knowledge on the topic. Thanks
Oh and window sticker i found of my truck says 3.73 gears....I dont think id be that happy with keeping these forever, i know ive read some say thats plenty, but i think i disagree
Big_Smokey is offline
post #2 of 12 Old 03-26-2014, 03:23 AM
B585Ford's Avatar
What size tires did you have beffore? Do you prefer it to be geared more like stock or how it was with your last tires?
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #3 of 12 Old 03-26-2014, 03:39 AM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
35/12.50/18 It was better with 35s,
Went th 37/13.50/20, so the wheels also changed weight
Stock it was a flat beast, which I liked the best. I'm up for a compromise though
post #4 of 12 Old 03-26-2014, 06:19 AM
B585Ford's Avatar
Ok, easy to calculate....new tire size divided by old tire size multiplied by current gear ratio. So 37/33x3.73 = 4.18 so 4.10s or 4.11s. I can't remeber which is available for this rear end would be very close to a stock setup. That would be slightly less gear (you would turn a little RPM at the same speed) than stock. On a SRW F250, if you wanted more gear, I am not sure what is available but maybe 4.33 or somewhere around there (you would be turning more RPM than stock at the same speed).
B585Ford is offline
post #5 of 12 Old 03-26-2014, 05:36 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
Cool. Im just digging into the gear thing. Id really like to install my own, ive did everything else so far....plus we have a jeep id like to do as well. Ive never seen that equation before. Logged in the brain for now. Ill do some more searching on available options.. Thanks for your help
post #6 of 12 Old 03-26-2014, 05:39 PM
B585Ford's Avatar
My truck hasn't had stock tires since '08 so I cant remember the exact size from the factory. Before you do the final gear decision, make sure the factories are 33". I think that is it, but they might have been 32.5"
B585Ford is offline
post #7 of 12 Old 03-26-2014, 05:43 PM
Ontario Trucker's Avatar
I agree with B5, 4:10s if you can get them.....
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
post #8 of 12 Old 03-26-2014, 06:22 PM Thread Starter
Big_Smokey's Avatar
Quoted: 8 Post(s)
32.5 is pretty close. Calculates out to 32.6
Pretty sure 410, but havent had any time to dig around yet. Ill probably hold off a bit as id like to do a locker as well while im in there
post #9 of 12 Old 03-26-2014, 07:18 PM
Yes a locker is a good idea as well
post #10 of 12 Old 03-26-2014, 07:41 PM
B585Ford's Avatar
That actually calculates out to 4.23 so 4.10 would be in the middle of stock and 35s. 4.33s are available for the dually F450s, but I don't know if available for yours. I still kind a lean towards the 4.10s cause you can always add a little powa if need a little more to get them big ole tires rollin, but you will still keep your RPMs on the highway in a good fuel economy range.
B585Ford is offline
