SCT Livewire TS = garbage.... - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 27 Old 03-18-2014, 05:09 AM Thread Starter
NavPaul's Avatar
My exhaust back pressure is reading 47 psi with key on engine off, obviously when the engine is running it is way off...units are incorrect.
Units for boost are not correct, when I have it in PSI they are way off. Seems that when I put it in kPa they read what they should if it was in PSI.
My boost signal constantly maxes out causing me to have to keep resetting my max/mins.
Yesterday I did a part throttle pass, just got on it a bit, I saw my TS tell me that boost was 22.4 (as if it was pegged) analog gauge was upward of 35-40.....
EGT max that was saved randomly reset after this......
Unfortunately the performance shop I purchased it from (I will withhold the name now because I have had no problems with them until now, I want to see how he resolves this for me) will not take it back unless I take a 10% restock fee which I feel is BS because it was not working from the beginning. Also, when it was in service to replace a screen at SCT they said they would investigate and they did NOTHING.
Now the retailer I purchased it from keeps telling me that everyone else is having the same problems and the issue is on SCT. Has anyone had ANY resolution of these issues? This is garbage and very annoying to say the least, I would never purchase this garbage again.
I have heard of people having a problem here and there but not ALL the issues I am having...
NavPaul is offline
The Following User Says Thank You to NavPaul For This Useful Post:
hoofdoctor (03-18-2014)
post #2 of 27 Old 03-18-2014, 05:19 AM
hoofdoctor's Avatar
Paul.......is this the 5015 model? I just ordered that system yesterday. If I have problems I sure hope my shop stands behind it! I'm not hearing a lot of negative chatter about the 5015???
hoofdoctor is offline
post #3 of 27 Old 03-18-2014, 05:24 AM
Mexfdmnb's Avatar
I have the 5015 model works flawlessly just make sure you update it might fix it
[SIGPIC]2005 F-250 CCLB zf6
leveling springs, 4" turbo back 5" tip
oil filter bypass, coolant filter
deleted, studded, sinister fuel filter cap,
SCT X3, S&B CAI, blue spring,
truxedo lowpro qt bed cover,
black diamond hg,
stand pipe, dummy plugs, stc fitting, Airdog 150,
Beans Diesel sump, edge insight cts, eadge eas pyro, turbo feed line,
Turbo drain tube, mishimoto 200* t stat, WW2
CCV MOD, High idle mod, PMF traction bars, 08 diff cover, 20" led light bar
Mexfdmnb is offline
post #4 of 27 Old 03-18-2014, 05:25 AM Thread Starter
NavPaul's Avatar
Yes sir that is the one, make sure and ask them because I am very upset with my scenario. Had the shop told me as he claims now that SCT is having all of these issues then I would have never bought it.....
NavPaul is offline
post #5 of 27 Old 03-18-2014, 05:26 AM Thread Starter
NavPaul's Avatar
YES, thanks for bringing it up, it is updated to the newest....
NavPaul is offline
post #6 of 27 Old 03-18-2014, 05:27 AM Thread Starter
NavPaul's Avatar
YES, thanks for bringing it up, it is updated to the newest....still having all of the issues. Now here is where the shop I bought it from is BSing me. He is saying that other people are having all of the same problems, he said if he took a new one off the shelf I would have all of the same issues, so you my friend just proved to me that he is being dishonest.
Thank you.
NavPaul is offline
post #7 of 27 Old 03-18-2014, 05:29 AM
hoofdoctor's Avatar
I sure will! I'll be talking with the shop today. If I get any updated info to pass along I will post it up.
post #8 of 27 Old 03-18-2014, 05:30 AM Thread Starter
NavPaul's Avatar
Sounds great! Thanks
NavPaul is offline
post #9 of 27 Old 03-18-2014, 09:47 AM
Zack birge's Avatar
Im running the livewire ts comp model. Zero flaws with mine
'15 F-250 Platinum CC/SB Black
Just a couple go fast goodies!
PPEI Tuned, No Limit Fabrication goodies, 5" FloPro
22x12 Rockstar 2'w 35" Terra Grappler G2's
Zack birge is offline
post #10 of 27 Old 03-18-2014, 02:02 PM
I just installed the live wire comp and also have the same issues... I'm very interested if you find a solution!
sliverbullet is offline
The Following User Says Thank You to sliverbullet For This Useful Post:
Smokin_KingRanch (05-12-2014)
