Yet another EGR delete question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-15-2014, 08:05 PM Thread Starter
wellsit's Avatar
I was planning to delete my EGR this weekend but got stuck at the bolts holding the lower unit in place. From what I've read in other posts, it is common that these 2 are a real pain. What I haven't been able to find is how folks are removing them.
I decided to start with these two bolts to see if I could break them free before I started hacking on everything else. This way, if I failed (which I did), my truck won't be un-driveable.
What I need to know is how people are removing these bolts. I tried a breaker bar for more leverage but that didn't work. I actually broke my socket. I was using a 10mm craftsman 6 point socket and it cracked. I was surprised. I think next time I'll try an impact socket that hopefully won't crack under the pressure.
I've heard of some using a grinder to cut and grind their way through the bolt head. It seems like there isn't enough space to get a grinder wheel in there.
So, how about it? How did you get those things the break free?
08 F350 6.4
H&S Mini Maxx Street
wellsit is offline
post #2 of 11 Old 03-16-2014, 04:58 AM
Big_Smokey's Avatar
Quoted: 8 Post(s)
lots of PB blaster, then go to bed.....maybe blast it some more.....go to bed....then get to work.
Mine actually came off pretty easy after some lube
Big_Smokey is offline
post #3 of 11 Old 03-16-2014, 05:54 AM
B585Ford's Avatar
What he said and after PB being on there for 24 hours or so giving it a little heat if needed. When I helped a buddy do his, he used PB 48 hrs before we started. We didn't have to use heat.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #4 of 11 Old 03-16-2014, 06:20 AM Thread Starter
wellsit's Avatar
I soaked them with pb a couple hours before I started. I guess I'll soak them again today and try again.
Thanks for the replies.
wellsit is offline
post #5 of 11 Old 03-16-2014, 06:52 PM
B585Ford's Avatar
I think it does take a while to penetrate into the threads so hopefully it will be easy when you try it.
B585Ford is offline
post #6 of 11 Old 03-17-2014, 09:29 AM Thread Starter
wellsit's Avatar
I gave the bolts another soaking and was able to break the lower one free. The upper bolt just rounded the head. I'm not looking forward to getting a cutoff wheel in there since the clearance is pretty small with that bung right next to it.
08 F350 6.4
wellsit is offline
post #7 of 11 Old 03-17-2014, 10:05 AM
Sam Hain's Avatar
How are you trying to get at it? I removed the drivers side inner fender and came at it from the side. I didn't use any PB blaster and was able to get both off no problem.
Sam Hain is offline
post #8 of 11 Old 03-17-2014, 10:09 AM
SpDyDaVe's Avatar
I did the same process and no issues other than tearing some skin off my knuckles. If you are using a 6 point socket try stepping up to a 1/2 drive bar for leverage. Sorry you are having issues with those bolts and glad mine were easy. Good Luck sir.
2008 F250 CCSB Lariat
Spartan 350, Extreme Studs, Elite Lifters, Smith Bros Pushrods, RCD (Oil Pan, Manifold, Up pipes w/EGR), 6.0 Manifolds, S&B CAI, 4" SS DP, 5" SS Exhaust, Sinister Coolant Filter, Mishimoto Intercooler & Rad, K&P Oil Filter, OUO (ALA'S, Traction Blocks, Short Gusset Bars, Pin Kit, Top Plate, Track Bar), ICON (2.0 Front, Rear, Dual Steering, Springs, TEI)
NRA Life Member
SpDyDaVe is offline
post #9 of 11 Old 03-17-2014, 10:14 AM Thread Starter
wellsit's Avatar
I took the fender liner out too. Trying to come in from the side. The bolt is in so tight that it rounded the head. I tried to be patient and not ruin it but too late now. It is just one stinking bolt holding me up!
08 F350 6.4
wellsit is offline
post #10 of 11 Old 03-17-2014, 10:21 AM
Sam Hain's Avatar
Have you seen this thread? He had the same problem.
EGR Delete-Full Install (Long+Pics)
Sam Hain is offline
