side exhaust - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-10-2014, 07:29 PM Thread Starter
side exhaust
anyone ever ran the exhaust out the side BEFORE the rear tire? Trying to figure out a good way to run it under the bed. It does sound a lot better than the full exhaust
mostroker64 is offline
post #2 of 3 Old 03-10-2014, 07:38 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
If you are deleted your truck will get pretty black down the side eventually. Even if you don't see smoke it slowly builds itself up. I guess if you wash your truck a lot it's not a problem tho.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #3 of 3 Old 03-12-2014, 07:26 PM
B585Ford's Avatar
Mine is the standard after the wheel so it doesn't show bad on the truck cause it is black but my chrome bumper doesn't take any time to accumulate some soot. I seriously doubt it would sound much better anyways....compound turbos with a VGT HP turbo just don't sound good from the exhaust side of things. If you would be happy if it sounded better at idle you can use MCC or buy a program that turns off the VGT up to 1100 RPMs. If you want it to sound good all the time go to a single.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
