Propane pros/cons - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-10-2014, 10:54 AM Thread Starter
Propane pros/cons
This isn't much for performance talk, but I hear good things as far as fuel mileage goes. Can someone give me a little info on it? How much it costs, what's needed, is it hard on the motor... Any info would be much appreciated.
09powerstrokee is offline
post #2 of 11 Old 03-10-2014, 12:59 PM
08stroker250's Avatar
I've never heard of anyone running it on a 6.4. I've always known it to be a bad idea because it increases pre-turbo EGT's quite a bit. Maybe someone will chime in with more info, but I don't think you'll get much from the 6.4 guys.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 11 Old 03-10-2014, 01:40 PM Thread Starter
Well that is actually good to know. I wasn't so sure if it would increase egts and screw stuff up. I'm just trying to squeeze every bit of fuel out as efficient as possible lol diesel prices keep climbing so I need a fix ha
post #4 of 11 Old 03-10-2014, 04:23 PM
Quoted: 769 Post(s)
Its only a bad idea if you dont know what your doing. Too much propane pressure is bad. Only a few psi for mpg gains. I've chatted with the guy on ebay quite a bit and he's sold a few thousand kits and supposedly hasn't had anyone complain. Badger performance. Iirc.
Corey@CNCFAB is offline
post #5 of 11 Old 03-11-2014, 03:28 AM
B585Ford's Avatar
If he sells them, his opinion may be biased...wouldn't you agree? IMO propane + 6.4 = bad idea. I don't like the thought of injecting a flammable fuel into the boosted air coming in pre-cylinder. I don't know if a very low pressure nitrous system could provide enough improvement in fuel economy to offset the cost, but that is the only system I would consider. I admit, I have never been a fan of injectibles though.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #6 of 11 Old 03-11-2014, 07:01 PM
No offense meant, but you might want to read up on nitrous. It is not a fuel, it is an oxidizer that allows you to burn more fuel. N2O would certainly not help economy.
CobraChris is offline
post #7 of 11 Old 03-11-2014, 07:14 PM
Correct. The major benefits of nitrous are cooling EGT's and burning more fuel to make more power.
Jeff Dodd
post #8 of 11 Old 03-11-2014, 08:11 PM
B585Ford's Avatar
Exactly, that is my point. It is not a fuel so I feel more comfortable injecting it. It does improve efficiency though. I am pretty sure it could help if used properly. 6.4s have stingy heads thus why they do so well with nitrous. Forcing air down stingy heads takes energy. Nitrous in a low pressure setup would allow you to make the same HP without wasting so much energy (in the form of EBP). Would it improve efficiency enough to offset cost...IDK
B585Ford is offline
post #9 of 11 Old 03-11-2014, 11:55 PM
Quoted: 769 Post(s)
I would agree that he very well could be biased, but there are literally 1,000's of fleet trucks running propane MPG add on kits. From light P/U's to class 8 trucks.
This is one of the few companies I would trust. http://www.transtechenergy.com/propa...sel-injection/
Anyone that advertises as a diesel performance shop I would be hesitant. As they are more times than none just cookie cutter parts jockeys. But not all of course.
post #10 of 11 Old 03-12-2014, 03:38 AM
B585Ford's Avatar
This is one of the few companies I would trust. Propane Diesel Injection
Good point. If you or the OP decides to go that route, I hope it works out for ya. Like I said in the beginning,, I am biased against I injectibles...if people go this route on the 6.4 and it works well, who knows, I might even try it.
B585Ford is offline
