Intake advice? - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By 08stroker250
  • 1 Post By B585Ford
post #1 of 10 Old 03-09-2014, 06:26 PM Thread Starter
Intake advice?
Which after market intake manifold would you recommend where I don't have to do a fuel bowl delete. Shimming the bowl up is no big deal.
Thanks in advance...
GSchretter is offline
post #2 of 10 Old 03-09-2014, 06:52 PM
08stroker250's Avatar
River City Diesel has a nice ported manifold. I assume you don't have to do a fuel bowl delete to run it. Is a fuel bowl delete required with Elite's manifold?
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #3 of 10 Old 03-09-2014, 06:58 PM Thread Starter
I don't think so as most offer stages but it seems stage 2 where they remove that bend where the fuel bowl goes does require a fuel bowl delete.
I've never even heard of a fuel bowl delete or why would someone want to do this. In guess mainly for stage 2 intake manifolds..
Thanks for the info on RCD
post #4 of 10 Old 03-09-2014, 09:07 PM
Removing the fuel bowl allows you to pump directly from the LPFP to the HPFP. Elite makes a kit and I believe Maryland Performance Diesel does as well.
GSchretter likes this.
Jeff Dodd
post #5 of 10 Old 03-09-2014, 10:30 PM
B585Ford's Avatar
Fuel bowl deletes don't do much for stock fuel/stock turbos other than cleaning up the engine bay and you remove one more thing that could cause problems.
If you do a LP fuel system upgrade such as AD, FASS, Fuel Lab, or some custom ones, you don't need the filter in the fuel bowl so you either have to leave the bowl empty or run a filter in the bowl and change it routinely.
If you add fuel (dual fuelers, modded K16), the fuel bowl can become a restriction on the system and the HPFP(s) might starve for fuel at WOT.
If you upgrade your turbos, some of them don't fit without the fuel bowl being deleted.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #6 of 10 Old 03-10-2014, 06:18 AM Thread Starter
Wow sounds like a great upgrade.
Thanks guys!
post #7 of 10 Old 03-10-2014, 07:19 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Midwest diesel also offers ported intakes (I believe they have 3 stages). A guy on here ported my intake manifold for me.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 10 Old 03-10-2014, 08:23 PM
TD-5's Avatar
Quoted: 3 Post(s)
I have a stage 1 with pipe plugs threaded directly into the manifold. Not impressed.
Go with a manifold that has bungs tig welded into the manifold & uses ORB plugs. Once you decide on a particular manifold try & get some fed back on it from actual users, a poor welding job can warp the manifold runners.
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
post #9 of 10 Old 03-11-2014, 05:32 AM Thread Starter
Good point, I've learned my lesson with 6.4 after-market parts warping.
Any ideas who has one like that?
post #10 of 10 Old 03-11-2014, 07:21 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
The guy that did mine is a member on here. He has a jig that he bolts the manifold to and welds it so that it doesn't warp. He also has a reasonable price. PM me if your interested in his info. I also have pics.
08 F350 cc/sb 4X4
