Exhaust System Advice - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By kinnisoj
post #1 of 10 Old 03-09-2014, 09:51 AM Thread Starter
08StormTrooper's Avatar
Looking at doing a turbo back dual exhaust kit for my '08 350. Im going to attempt to custom fab some tips to fit through the (unnecessary) cutouts in my Smittybilt M1 rear bumper. A few questions:
1. Is there a huge difference in 4" and 5" pipes?
2. If i do 4" pipes do i really need to do a turbo back swap since the factory is 4" (i believe?)
3. What brand, if any one brand is better than the other?
'08 Ford F-350 Super Duty
6.4L V8 Turbo Diesel
DPF/CAT delete
EGR delete
AFE Stage II R5
H&S XRT Pro
AFE 4" Turbo back exhaust
AFE Turbo Intercooler
Strokin' since the start.
08StormTrooper is offline
post #2 of 10 Old 03-09-2014, 12:35 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Difference between 4" and 5" is just sound unless you start getting real real high HP and then you need the flow of a 5.
All downpipes are 4". The stock downpipe is super constricted, I would change it no matter which you decide.
The only difference in brands you will find is material and maybe fitting a little easier or harder. Nothing a little elbow grease can't fix. Also as far as material, in Texas with no salt on the roads doesn't really make a difference. Aluminized holds up fine. Unless you really want to spend the extra coin on stainless just because.
Sent from AutoGuide.com App
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
The Following User Says Thank You to CountryAggie For This Useful Post:
imk0001 (03-10-2014)
post #3 of 10 Old 03-09-2014, 12:42 PM Thread Starter
So, here is my plan: 4" turbo back exhaust, split it, and fab those tips we had talked about? any recommendation on where to get the pipe kit in order to not spend an arm and a leg?
DPF/CAT delete
EGR delete
AFE Stage II R5
H&S XRT Pro
post #4 of 10 Old 03-09-2014, 12:50 PM
Look thru the site sponsors and give one of them a call. They might be able to find you a discount for you being an org member.
-Tyler
Texas A&M c/o 2010
post #5 of 10 Old 03-09-2014, 01:24 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Here's the diffrence between the 4" and the 5", if you get the 4" your always gonna wonder if the 5" would have been better.If you buy the 4" your gonna always be thinking about the 5" and be asking yourself- Would the 5" perform better? Would your egt's be 25* or 35* or even 50* lower? Would it sound tougher when you romp on it? Would your dog still have run away if you had the 5"?Would you be able to get a lower mortgage rate on the new house if you had a 5"? Would your Doctor insist on that extra prostate check up if you had the 5" system.....well okay you get my point. Go with the 5 and never look back.
GSchretter likes this.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 10 Old 03-09-2014, 02:09 PM
Hahaha that's funny. For what it's worth I run a 5", but I'm never happy with the HP I have and want more... But power and EGT wise there won't be a noticeable difference until you are at 600+hp. There is a definite sound difference tho. The 5 has a deeper tone to it.
-Tyler
Texas A&M c/o 2010
post #7 of 10 Old 03-09-2014, 02:30 PM Thread Starter
won't let me quote you. but since you put it that way.. I'm gettin a 5"
DPF/CAT delete
EGR delete
AFE Stage II R5
H&S XRT Pro
post #8 of 10 Old 03-09-2014, 04:23 PM
Brushdawg's Avatar
Me too....
Brushdawg is offline
post #9 of 10 Old 03-09-2014, 06:34 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Good choice.Your dog thanks you!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 10 Old 03-09-2014, 07:15 PM Thread Starter
Yes ol' Jed (my redbone coonhound/black mouth cur mix) does.
Love the sound of your exhaust by the way. Just watched your YouTube vid.
DPF/CAT delete
EGR delete
AFE Stage II R5
H&S XRT Pro
Tags
6.4 , 6.4l , exhaust , f350 , turbo back
