Pro Comp vs Other - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-07-2014, 09:11 PM Thread Starter
Pro Comp vs Other
How do you guys feel about Pro comp components compared to the more televised, or brand name, promoted components, such as Icon, Skyjacker, Bds and all the others. Just looking for pros and cons of Pro comp and if its a cheap brand meaning the stuff doesnt last or is poorly manufactured compared to the more popular brands. Thanks in advance fellas
Mmace111 is offline
post #2 of 10 Old 03-07-2014, 09:14 PM Thread Starter
Maybe i should have added in im under the assumption that it is the cheap way out and im not sure why i think that so any questions answered or comments would be helpful
Mmace111 is offline
post #3 of 10 Old 03-07-2014, 10:18 PM
B585Ford's Avatar
I don't have any experience with Pro Comp suspension components. I did a 2.5" Ion level kit and added 1" with my traction bars. The ION has been on there 6 yrs now w/o issues and the Tbars are a little over 2 yrs.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #4 of 10 Old 03-07-2014, 10:37 PM
srjd's Avatar
Quoted: 2 Post(s)
My pro comp 6 inch has been on for 6 years as well I work in the oil field so my truck takes a beating and my lift has held up extremely well. My 6.0 had fabtech it road a bit softer. I find pro comp springs to be stiffer then most which I like because I don't have traction bars I feel it helps with Axel wrap. The rear springs won't even hit the stop or whatever you call it even when I'm loaded very heavy
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 10 Old 03-07-2014, 10:41 PM
B585Ford's Avatar
I definitely recommend AGAINST Fabtech Tbars.
B585Ford is offline
post #6 of 10 Old 03-07-2014, 11:12 PM
08stroker250's Avatar
OP, Pro Comp has some good stuff. I just don't recommend their traction bars. I've been there and done that. I do recommend ICON over anything else matched with Precision Metal Fab parts, but not everyone is willing I spend the money on a setup like that.
I assume you're referring to an ICON leveling kit? I've never heard of Ion.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #7 of 10 Old 03-07-2014, 11:16 PM
B585Ford's Avatar
Yes, that is correct. Thanks for catching that.
What problem did you have the Pro Comp Tbars?
B585Ford is offline
post #8 of 10 Old 03-07-2014, 11:19 PM
layson's Avatar
Quoted: 79 Post(s)
I am an Icon guy. Can't go wrong with them. I would match them with One Up Offroad.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #9 of 10 Old 03-08-2014, 11:40 AM
They just didn't function properly. I've tried Pro Comp, CalTracs (racing purposes only), and PMF. The Pro Comp bars were the least effective bar out of all three. The PMF bars were by far the most effective.
Jeff Dodd
post #10 of 10 Old 03-09-2014, 09:26 PM Thread Starter
Thanks for the feedback guys i think ill look more into icon and see what i can find that is feesable
Mmace111 is offline
