HELP !!!!!....Better MPG Spartan tuner - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 15 Old 03-02-2014, 05:07 PM Thread Starter
Angry HELP !!!!!....Better MPG Spartan tuner
I have a Spartan tuner on my 6.4 powerstroke, it has been egr and dpf deleted with a s&b intake installed. I am trying every single tune on my Spartan and the best mpg I can get is 12.....help please!!!! love my truck but need better mpgs. I traded a 06 dodge dually that got 19 for this damn thing. I know it can get better...hell my 04 6.0 got 19.........!
hlywd2 is offline
post #2 of 15 Old 03-02-2014, 08:36 PM
bentstroke_02's Avatar
Where are you from?
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #3 of 15 Old 03-02-2014, 09:05 PM
B585Ford's Avatar
Are those hand calced or are you going by the lie-o-meter? Unfortunately, a 6.4 will never get great mileage. One of the reasons is the emissions crap which you did remove. Weight of the truck, stingy heads (which means you have to run higher EBPs and boost), and compound turbos also don't help.
If you run a tune with aggressive timing (the 310 for example) and can resist the skinny pedal, you should get the best mileage.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #4 of 15 Old 03-03-2014, 05:01 AM Thread Starter
yes it is hand calculated at the pump...I ran the 310 tune for a 2 days and it wasn't quite running right it felt like the injectors were failing, the power was cutting in and out.
hlywd2 is offline
post #5 of 15 Old 03-03-2014, 06:11 AM
B585Ford's Avatar
Was it defueling? If so, do you know what parameter was causing it to defuel?
B585Ford is offline
post #6 of 15 Old 03-03-2014, 06:14 AM Thread Starter
i have no idea really what that is?!
hlywd2 is offline
post #7 of 15 Old 03-03-2014, 06:16 AM Thread Starter
im new to the 6.4 and 6.7. still learning them
hlywd2 is offline
post #8 of 15 Old 03-03-2014, 07:39 AM
B585Ford's Avatar
Defuel is what the truck's computer (PCM) does to protect itself. Spartan offers quite a number of different parameters you can set to trigger a defuel. For example, if you worried about your pistons, you could set the EGT defuel to 1450. If EGTs got 1450 or higher, the truck's computer will automatically cut back on fuel to lower the EGTs.
B585Ford is offline
post #9 of 15 Old 03-03-2014, 08:59 AM
lx5spd's Avatar
I thought Spartan did not offer adjustable defuel parameters.
floorboy likes this.
2008 Ford F-250 Lariat
2007 Suzuki GSXR 600
2001 Suzuki DRZ SM converted
2007 Suzuki LTR-450 Quadracer
lx5spd is offline
post #10 of 15 Old 03-03-2014, 09:53 AM
B585Ford's Avatar
I never ran a Spartan but I am pretty sure they do. As a matter fact, I am pretty sure they let you use EBP as a defuel parameter (which I would have loved with my old setup). PM Jeff if you want to confirm.
B585Ford is offline
