egr blocker plates - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-02-2014, 01:45 PM Thread Starter
STEVEFX64's Avatar
egr blocker plates
i ordered some blocker plates from river city diesel and when they came in the mail i think one of them may be the wrong one. ill attach a picture. also guys who have done this before anyone got any tips that might make the install go easier. ive heard of it taking 30 mins or taking 3 hours...
2010 F250 CCSB FX4 h&s XRT pro 300 4" sinister exhaust RCD EGR delete s&b dry intake 285/65/20 bfg at on factory 20"s tinted Windows undercover bed cover
STEVEFX64 is offline
post #2 of 10 Old 03-02-2014, 02:18 PM
dnaber's Avatar
I wish I could help, but I also plan to use the block off plate, so I'll be following this thread. Good luck and I know someone will be around soon to provide you with help.
Don
Sent from AutoGuide.com App
Don Naber
USAF (Retired)
Middleburg, FL.
God Bless America, And All That Serve This Great Nation
dnaber is offline
post #3 of 10 Old 03-02-2014, 04:31 PM
StrokiNDieseL's Avatar
I did the delete but if one goes down by horizontal cooler then removing the driver side wheel-well might be easier. Good luck, Jayson.
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #4 of 10 Old 03-05-2014, 03:05 AM Thread Starter
STEVEFX64's Avatar
Talked to rcd yesterday they said they were the right plates. Hope to get them in this weekend maybe. Will take pictures and let you know how the install goes
post #5 of 10 Old 03-06-2014, 06:21 AM
Now that I'm reading about the Block off plates I'm wondering the pros and cons vs the full delete?(in a place where every 2 years I will need emissions) Obviously if I never had to deal emissions the full delete would be the only way to go but now I'm thinking I should do the block off plates . Thoughts?
Blown99 is offline
post #6 of 10 Old 03-06-2014, 09:18 AM
cbenn's Avatar
Quoted: 3 Post(s)
I run block off plates along with bulletproof EGR coolers, reason I went that route with coolers if Washington state ever goes to inspections they are there for a visual and if I do need to switch back at least I have good coolers. I also have Rudy's delete kit sitting on the shelf for sometime later, the plates do what they were intended for, I used the plugs in the kit for the coolant side believe it was /2 plugs to change out. The install of the plates is about 30 minutes and doing the plugs will take about 1.5 hours. See my signature for what is done on the truck. Good luck
Just purchased a new 2016 CC
SOLD
2008 F350 CC SRW, 4X4/LB
Spartan Tuned/Spartan TCM
1722 Elite Head Studs/ChromeMoly pushrods
Bullet Proof 1/2 oil cooler kit
4" Down Pipe/4" DPF/Cat Delete
Diamond Eye 5" DPF back/5" Areo Turbine Muffler
3" CAI/inter cooler
S&B-CAI
CCV mod w/catchcan
Big Wig Sway Bars
PMF Traction bars
Icon 2.5 front coil springs
Bilstein shocks/Top Gunz dual stabilizer w/Bilsteins
Airlift/remote airbags
Viper 5701 w/SmartStart
cbenn is online now
post #7 of 10 Old 03-10-2014, 09:06 AM
In for this one, I've got the same plates sittin in the shop and haven't tackled it yet. Let us know how it goes. Pics would be great also
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #8 of 10 Old 03-19-2014, 07:49 AM
dnaber's Avatar
SteveFX64, so have you done the blockoff plates yet? Just checking as it is next on my list. Thanks
Don Naber
USAF (Retired)
Middleburg, FL.
dnaber is offline
post #9 of 10 Old 03-19-2014, 08:27 AM
jcook933@gmail.com's Avatar
Just installed RCD'S full delete with elbow. Great product! I will recommend that if you are just doing block off plates and coolant plugs, or just block off playes, make sure you have a couple of gallons Ford gold or whatever coolant you are running. By the time I was done pretty much drained the entire system. Good luck.
BEASTPSD
jcook933@gmail.com is offline
post #10 of 10 Old 03-20-2014, 07:25 AM
pack77
Guest
Posts: n/a
Quoted: Post(s)
When you install a egr delete kit do you have to also install a tuner?
