Gearbox Z DPF-R 4.0 Plus VS SCT3015R - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-27-2014, 04:10 AM Thread Starter
dnaber's Avatar
As you can see I'm like many trying to figure out which direction to go as far as a new tuner. I'm on the fence and need a little push as to which to purchase. Here is what I've got os far:
Both:
DPF delete.
EGR disable.
DPF-R 4.0 Plus:
$700.00 w/pipe
Simple installation. Voice commands
Not upgradeable. No USB interface.
No additional tunes except the 70 HP increase.
Can block the EGR but can't remove it.
No transmission changes.
SCT 3015R:
$800.00 w/pipe
Simple installation. Digital display.
Can be upgraded. Has USB interface.
Comes stock with 4 tunes. Can aquire additional tunes $$
EGR can be removed with this tuner (so I'm to understand)
Both Engine & Transmission Tuning!
High Speed Datalogging and Instrumentation via a large backlit display
Built-In Programmable Shift & Alert Light
Pre-Loaded Performance Tune, Towing Tune & Transmission Only Tune
Read & Clear Diagnostic Trouble Codes
Adjustable Shift Points
Displays estimated HP, TQ, 1/4 Mile ET’s & 0-60MPH
Speed Limter Removed / Rev Limiter raised to 4300RPM
I see all the pro's but I need to see some con's as well. Let me hear the reason I should buy one over the other. Please don't try to include the H&S or Spartan, I know they are great for what they do but I'm also trying not to break the bank, I'm just trying to stick to one of these two.
Thanks
Don Naber
USAF (Retired)
Middleburg, FL.
God Bless America, And All That Serve This Great Nation
dnaber is offline
post #2 of 9 Old 02-27-2014, 04:56 AM
Sam Hain's Avatar
You can buy custom tunes with the sct also.
Sam Hain is offline
post #3 of 9 Old 02-27-2014, 07:20 AM
Franchi's Avatar
Feedback Score: 22 reviews
Where do you see a 3015 R with pipe for $800? That's a deal if it's an actual legit 3015 R
Just curious.
Franchi is offline
post #4 of 9 Old 02-27-2014, 07:32 AM
I'd go sct obviously I don't actually know you... But, from the way it sounds you're gonna want to upgrade later down the road. As the rest of us on a budget new turbo here, fuel there, this an that... Lol. With the sct you'll be able to accommodate those parts later. The dpf-r will not
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #5 of 9 Old 02-27-2014, 07:44 AM
If you can get them for practically the same price then why wouldn't you go with the tuner that can do more? Seems like common sense to me
Where are you finding the SCT with pipe for $800? I went with the dpf-r plus and love it but if I could have found the SCT for the same price I would have went with that
jgos929 is offline
post #6 of 9 Old 02-27-2014, 08:57 AM Thread Starter
dnaber's Avatar
Issue solved!!!! I just bought a SCT 3015 X3 at a great price. Now to find a pipe.... the search continues. Thanks to all that replied.
Don Naber
USAF (Retired)
Middleburg, FL.
dnaber is offline
post #7 of 9 Old 02-27-2014, 09:43 AM
Franchi's Avatar
Just make sure that whatever you bought is a 3015 R model which is the one needed for DPF delete tuning for the 6.4.
A regular 3015 SF3 or X3 3000 model wont do dpf delete tuning.... Gets confusing I know...
Franchi is offline
post #8 of 9 Old 02-27-2014, 09:50 AM Thread Starter
dnaber's Avatar
Thanks Franchi, This is the same model that Rudy's sells.
Don Naber
USAF (Retired)
Middleburg, FL.
dnaber is offline
post #9 of 9 Old 02-27-2014, 09:50 AM
sabarnes's Avatar
Can I muddy the water a little more. with the Gearbox, Tachyon Plus Tuner ($743.00) for Ford 6.4L 2008-2010 trucks, with aFe CAT/DPF Delete Race Exhaust.
Features:
•Worlds Smallest Programmer
•Reprograms the ECU for trouble free EGR/CAT/DPF delete
•Voice Prompted menu system
•Reads and clears DTCs
•5 Power Levels
•Anytime Safe And Easy Power Level Change
•Fully reversible
•Easy Install ◦No Drilling
◦No Cutting
◦No Welding
•aFe Exhuast: ◦4" Stainless Steel
◦Mach Force Xp
◦Factory Style Hanger
◦Tappered End
Includes:
•Tachyon Plus Tuner
•aFe Stainless Steel CAT/DPF Delete Race Pipe
sabarnes is offline
