Boost - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-23-2014, 06:38 PM Thread Starter
diesel212's Avatar
Boost
I run my mini maxx on mild 250hp setting and in my opinion hit my boost defueling 38psi way to easy anything I can do for this
2008 6.4
H&S mini maxx
5" Flo Pro
Volant intake
20" Rockstars on 33's
diesel212 is offline
post #2 of 7 Old 02-23-2014, 07:01 PM
Lipka101's Avatar
Quoted: 75 Post(s)
Turn your defuel setting up a little. I have seen my boost at 49psi. I have read that youre safe up to 50 psi without a waste gate.
2008 f250 ccsb kingranch
Sct Livewire with innovative custom tunes. Edge insight cts.
Mbrp dpf/cat delete. PMF stage 2 traction bars.
Drp egr delete w/wastegate. LP batmowheel, 20x12 fuel hostage with nitto trail grappler. 12.9 sec. 1/4 mile at 104.5 mph
Lipka101 is offline
post #3 of 7 Old 02-23-2014, 07:02 PM Thread Starter
diesel212's Avatar
Wow really I keep reading to keep it no more then 40psi without studs
2008 6.4
H&S mini maxx
5" Flo Pro
Volant intake
post #4 of 7 Old 02-23-2014, 07:09 PM
Lipka101's Avatar
Quoted: 75 Post(s)
I could be wrong. I'm not an expert. Next solution if you want to be safe with it is to run on lower tune. thats how it works, bigger tune higher boost and I'm pretty sure boost isn't what kills head gaskets it's back pressure although I believe they are similar. I will run mine like it is and replace gaskets an put studs when I need them. I say fix it when it breaks.
Lipka101 is offline
post #5 of 7 Old 02-23-2014, 07:12 PM Thread Starter
diesel212's Avatar
Thanks for the help gonna try going down to the 175hp setting see how that goes
2008 6.4
H&S mini maxx
5" Flo Pro
Volant intake
post #6 of 7 Old 02-23-2014, 08:28 PM
WoodBoy's Avatar
Plenty of people run 45+ psi on stock studs. I have seen many people run 50+ on stock studs. Doesn't mean you have to do it if you don't feel comfortable with it. Main thing is to make sure your truck is up to temp (185* or so) on coolant
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #7 of 7 Old 02-24-2014, 02:31 AM Thread Starter
diesel212's Avatar
I just tried that 250hp setting this weekend was reading people were getting a little better mileage on it I usually run on mild stock setting not interested in racing just longevity if truck
2008 6.4
H&S mini maxx
5" Flo Pro
Volant intake
