Dtc p252f - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-23-2014, 04:46 PM Thread Starter
Lipka101's Avatar
Quoted: 87 Post(s)
Dtc p252f
I have an 08 6.4 and I'm running innovatives x street tune. Whenever I get into it as soon as i let off it goes into reduced engine power and throws code p252f, which as I understand it's a high oil level code. I checked my oil of course and it's fine. I searched the forums but there's not much about this issue. What I've figured out is that it happens only on the newest p30 strategy from ford. The tune I have is the 3.01 version. Will a tune update fix this? Has anybody had this problem and figured out the solution. I have nowhere to start and I'm getting sick of it going into limp mode every time I want to have a little fun. Thanks
2008 f250 ccsb kingranch
Sct Livewire with Gearhead custom tunes. Edge insight cts.
Mbrp dpf/cat delete. PMF stage 2 traction bars.
Drp egr delete w/wastegate. LP batmowheel, 22x9.5 fuel hostage with nitto terra grappler. 12.9 sec. 1/4 mile at 104.5 mph
Lipka101 is offline
post #2 of 4 Old 02-23-2014, 07:33 PM
WoodBoy's Avatar
Call innovative, they will get you fixed up. The way the parameters were setup on the new flashes from ford to detect a leaking injector or etc. causes this since there isn't an actual oil level sensor it uses several parameters to come to the conclusion that your oil level may be rising from fuel dilution. The extreme tunes from IDP will cause it to trigger that code because of the tight tolerances Ford uses to try and "GUESS" that the oil may be gaining level but IDP will get you fixed up so you don't have that problem anymore
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 4 Old 02-23-2014, 07:38 PM Thread Starter
Lipka101's Avatar
Quoted: 87 Post(s)
I emailed them and the reply I got was to try and clean the ebp sensor and tube. I live right down the road from their shop so I will stop in one day after work and try. Thanks. Did you have this problem ?
Lipka101 is offline
post #4 of 4 Old 02-24-2014, 07:12 AM Thread Starter
Lipka101's Avatar
Quoted: 87 Post(s)
I went to innovative this morning and got updated tunes and a different stock flash that should take care of my problem.
Lipka101 is offline
