Electric exhaust dump - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-19-2014, 08:59 PM Thread Starter
Looking for some info. Have an 08. DPF still attached But have gathered enough money to delete. I live in Colorado and don't want to reinstall the dpf every year want to upgrade the downpipe keep the cat than do a 4" electric cut-out or "dump" before dpf. would this work? might be a dumb question but I don't know if that short of pipe would cause issues with backpressure. I know the cut-out wouldn't stop all smog from getting to the dpf but it would be no big deal at that point to open the cut-out and run a cleaning every once in awhile. just a thought what do yall think
strokedmybusiness is offline
post #2 of 10 Old 02-19-2014, 09:17 PM
WoodBoy's Avatar
Wont work. No where to mount it between the cat and dpf, just buy a race pipe that deletes the dpf/doc. You can run an aftermarket downpipe such as Powerstroker67's downpipe and your dpf/doc will bolt right back up to it like it would stock..
It is pretty easy to drop the dpf/doc as one piece and then reinstall. Don't buy just the dpf delete and leave the cat in place as that take more time than dropping as one unit. You have two bolts at the downpipe end and one clamp at the dpf exit end then the couple of plugs to unplug. I would buy an H&S or Spartan for this reason since you can just unplug the sensors and leave in the dpf/doc when you remove
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
The Following User Says Thank You to WoodBoy For This Useful Post:
strokedmybusiness (02-19-2014)
post #3 of 10 Old 02-19-2014, 09:20 PM Thread Starter
Alright thanks for the reply guess I could have looked before one of those late night ideas .... that seemed genius guess not
post #4 of 10 Old 02-19-2014, 09:25 PM
WoodBoy's Avatar
Another quick tip.. Instead of fighting those rubber grommets that the hangers are in for the dpf, just unbolt the whole hanger from the frame rail. I think there are two or three hangers, I cant recall exactly, but each one has three little bolts (maybe 12mm or 14mm nuts?)holding it to the frame. The race pipe doesn't need them as it doesn't weight anything
WoodBoy is offline
post #5 of 10 Old 02-19-2014, 09:27 PM
B585Ford's Avatar
I am with Woodboy. It would be much simpler to swap a pipe out. Unless you create something so that you can pull the cut-out pipe off and seal your DP so that you could remove the cut-out quickly, you will still have the cut-out on your truck when you are being test by the emissions people. Since the cut-out would be pre-DPF, I would bet they would fail you anyways.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #6 of 10 Old 02-19-2014, 09:35 PM Thread Starter
Thanks probably over thinking the whole deal. tryin to get way to tricky when ill most likely get caught anyways
post #7 of 10 Old 02-20-2014, 07:59 AM
SD350's Avatar
I agree with you on everything you said except i didn't have many issues with the grommets, i just sprayed a bunch of silicon lube in there and they slid right out.
I will also add that an air chisel/hammer makes this job much much easier the first time you do it. It will also keep you from destroying the existing pipe so that it can be re-used. Just my 2 cents.
The delete pipe makes it sound a little deeper than stock if you don't mind the "hairdryer" sound that everybody seems to hate. Never really bothered me, Its nice letting people know you have a couple of bad a** turbo's.
2008 F350 FX4 King Ranch CC SB
Spartan 275 and 210 Tow as main tunes, AFE CAI
+ Spartan =
SD350 is offline
post #8 of 10 Old 02-20-2014, 09:02 PM
WoodBoy's Avatar
Yeah the grommets have never been a problem for me either, it was just a quick tip incase he is ever putting the dpf/doc back on by himself. It is easier to pick it up IMO and slide those hangers in the holes and hand tighten a nut or two on the backside with your left hand. What did you need a air chisel for?
WoodBoy is offline
post #9 of 10 Old 02-21-2014, 07:12 AM
Just did this last weekend so my mind is still... Kinda... Fresh lol. I couldn't get the hangars out of the grommets so I did as previously stated and unbolted them from the frame. They are 13mm bolts for the 3 hangars. There is a small one right behind the dp. It only has 2 bolts holding it to the frame. Then there is a hangar on the dpf and one on the pipe immediately after the dpf. These each have 3 bolts holding them
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #10 of 10 Old 02-21-2014, 07:36 AM
SD350's Avatar
I used it to break the rust free taking the old exhaust off, where the pieces slide into one another. Just made things easier for me, instead of heating with a torch and warping everything. To each their own i guess.
I honestly never even thought of just taking the bolts out just seems too simple! haha
+ Spartan =
SD350 is offline
