H&S Mini Maxx - downloaded hot tunes and lost Cruise Control - Ford Powerstroke Diesel Forum
post #1 of 18 Old 02-19-2014, 04:48 PM Thread Starter
As the title says, I downloaded the hot tunes to my truck just to see how much they effected MPG. All seemed to go well. I input my tire size, low fuel setting is 0, transmission is tuned to TC lock in 4th and low shift points. Truck runs great and MPG seems to be at least as good as with the mild tunes.
The only issue is that now my Cruise Control doesn't work. Won't even turn on. Anyone else have this problem? I'll called H&S and the tech had never heard of this happening and his only advice was to reload the tunes.
Any advice or tips are greatly appreciated.
mhutch2 is offline
post #2 of 18 Old 02-19-2014, 04:54 PM
Quoted: 48 Post(s)
usually won't work right after you first flash the truck. shut it off and start it back up and your cruise should work
if it still doesn't, it's probably your brake pressure switch. total coincidence if it is. Happened to my 1 ton
drunk on diesel is offline
post #3 of 18 Old 02-19-2014, 04:58 PM
Never happened to me. I'm running the 300 tune and actually used my cruise today
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #4 of 18 Old 02-19-2014, 05:07 PM Thread Starter
Thanks for the replies. I'll see if it works tomorrow and will report back.
mhutch2 is offline
post #5 of 18 Old 02-19-2014, 06:41 PM
What drunk on Diesel said.
ALSO, I have my H&S hardwired into the truck. When I turn the ignition on the H&S turns on. Sometimes, if I run the Glow Plugs and the HS doesn't completely fire up in between energizing the key and starting the truck I notice that sometimes the Cruise Control doesn't work.
seafordguy is offline
post #6 of 18 Old 02-19-2014, 07:40 PM Thread Starter
I have mine wired to the purple wire, as well and have that same thing happen while I'm waiting for the glow plugs to cycle. I wondered if the "double start up" of the tuner would be an issue. I sure hope I don't have an ongoing/intermittent problem. I use my cruise all the time.
When I downloaded the hot tunes I started the truck when the tuner told me to and then took off to test drive it. Got home, parked it, then came in to eat dinner, so I'm hoping all will be well when I start up next time. I'll check it out tomorrow.
Thanks again for the tips.
mhutch2 is offline
post #7 of 18 Old 02-19-2014, 09:40 PM
Quoted: 48 Post(s)
where do you live that you need to cycle the glow plugs?
post #8 of 18 Old 02-20-2014, 01:53 AM
I only cycle them if it is below 20*, which is VERY rare. Once, a month or so ago, I didn't cycle at 16* and I had a bad rattle for about 2 seconds so I use 20 as my cut-off.
mhutch - if youve already started the truck and don't want to restart, you can reach down and flick the H&S manual switch down at the OBDII port and usually that will reset it and allow it to work.
post #9 of 18 Old 02-20-2014, 03:38 AM
Quoted: 48 Post(s)
yeah, that's cold!!!!
post #10 of 18 Old 02-20-2014, 05:54 AM Thread Starter
Cold? You don't know cold.
I live in Colorado at about 9000 ft. We usually don't get extreme cold but regularly see zero. It was 10 when I got up this morning.
We had a few inches of snow last night so I might not get out until later today to see if the cruise works. I'll let everyone know later tonight. Thanks again.
mhutch2 is offline
