H&s hot tune effects - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 65 Old 02-19-2014, 01:24 PM Thread Starter
Brysonperry's Avatar
My 6.4 has 180k+ on it now, wondering how hard is hot tune on the engine. Engine has been tuned most of its miles, and i love the trucks power but never run it on hot or wild because i'm not sure the impact it has on the engine. Of course romping on a diesel everywhere aint ganna make it last any longer but just wondering if its ok to run on hot every once in a while without having to worry bout my engine blowing or something
Brysonperry is offline
post #2 of 65 Old 02-19-2014, 02:31 PM
Stroked777's Avatar
i ran hd300 for a long time then blew my headgaskets. just remember you can only beat on something so long til it breaks or needs fixing,but you can run it on hot all day if you want, only hing hot does is change the pulse width of the injector, so just adds more fuel
2008 F350 King Ranch
Intaked-Deleted-Tooned-Cammed
PowerStroke 2.0: UNRATED
Stroked777 is offline
post #3 of 65 Old 02-19-2014, 04:26 PM
B585Ford's Avatar
Your right foot will be the biggest factor....like it was already mentioned, the PW is the only significant change.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #4 of 65 Old 02-19-2014, 04:35 PM
Capt dong's Avatar
Quoted: 5 Post(s)
no advance in timing?
x3 on how driver has biggest impact on health of engine.
08 F250 KR
08 F250 XL
Capt dong is offline
post #5 of 65 Old 02-19-2014, 04:51 PM
B585Ford's Avatar
No, timing is the same all 4 tunes that you load. That was something I was hoping would change when MCC was released, but it didn't. If you could change the timing and RP, you could have 4 completely different tunes (like EFI which has 5 completely different tunes).
B585Ford is offline
post #6 of 65 Old 02-19-2014, 05:03 PM
Capt dong's Avatar
Quoted: 5 Post(s)
havent had time to really look at mcc in depth. i guess custom would fill the need for something more specific.
08 F250 KR
08 F250 XL
post #7 of 65 Old 02-19-2014, 05:10 PM
B585Ford's Avatar
That is still a downfall with custom tunes...they can't adjust those parameters either (in the 4 tunes). When I first heard MCC was being released, I planned on having a tow tune, a mileage tune, a street tune, and all out performance tune. Unfortunately, that is not how it works. Right now, I have Matt's regular "performance" tune (I am not sure what he calls it on H&S) and I have his tow tune. I can only load 1 or the other. FYI even with a manual tranny, they are well worth it.
B585Ford is offline
post #8 of 65 Old 02-19-2014, 07:16 PM
StrokiNDieseL's Avatar
Unhappy
So what would be the purpose to purchase the tuning package from gearhead if only pw changes, rip off? Or should you receive a engine file for each tune purchased(I.e street,tow,race)? I know I got 3 trans files to load separately but only 1 engine file? Thanks, Jayson.
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #9 of 65 Old 02-19-2014, 07:55 PM
WoodBoy's Avatar
The ability to change timing and etc is there. The ability for Shift on the fly to swap timing tables between tunes isn't available. So whatever tunes you have loaded are all running the same timing table as each other. Doesn't mean the timing hasn't been altered. Your H&S tunes definitely aren't running the same timing as stock settings, its just that when you first program a set of tunes, you program the timing table and the tunes you will be shifting on the fly all will be running that same timing table but when you swap tunes on the fly, it will just change the pw settings. Smell what I'm stepping in?
lhood6.7 likes this.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
The Following User Says Thank You to WoodBoy For This Useful Post:
StrokiNDieseL (02-19-2014)
post #10 of 65 Old 02-20-2014, 02:24 AM
B585Ford's Avatar
^^^exactly what he said. I was only referring to when you load an engine file, the timing and RP are the same on all 4 of those tunes (stock, mild, wild, hot Damn). If you load a different engine file, you will have another set of 4 tunes (with a different RP and timing).
01wj likes this.
B585Ford is offline
