Help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-18-2014, 04:26 AM Thread Starter
Help
Hey guys so I've got my exhaust on now and have my Spartan installed. When I did the install I loaded the 210 race tune because I didn't wanna do a trans relearn that night but I still haven't changed the tune. I've got to pull a load later and was wondering if it's okay to pull with the 210 race or do I need to switch to the 210TP before I hook up?
Thanks!
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #2 of 8 Old 02-18-2014, 05:12 AM
WoodBoy's Avatar
You should be fine. I tow with 275 and up tunes all the time.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 8 Old 02-18-2014, 05:19 AM Thread Starter
Thanks. I wasn't as concerned about the power so much as I was with the transmission file on that tune. That amount of power and pretty much stock shifting worried me a bit. I don't need to be puttin a new trans in... I still have the dealer temp tag on the truck!
2010 F250 CCSB
06psd6.0 is offline
post #4 of 8 Old 02-19-2014, 01:50 PM
bentstroke_02's Avatar
275 will tow better and you will get better MPG
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #5 of 8 Old 02-19-2014, 03:30 PM Thread Starter
Well I didn't want to load any of the higher horse tunes because I don't have my intake installed yet but also we were goin out shortly after I got done. I didn't want to have the trans tryin to relearn with 4 other people in the truck thowin em around, ya know? My concern was the shifts not being firm enough on the 210 race tune since I don't think they change much in that file from the stock file. But hey she pulled like a beast compared to the few times I pulled before deleting. Completely worth it
2010 F250 CCSB
06psd6.0 is offline
The Following User Says Thank You to 06psd6.0 For This Useful Post:
GSchretter (02-19-2014)
post #6 of 8 Old 02-19-2014, 05:05 PM
WoodBoy's Avatar
Your trans has to relearn everytime you swap a tune. Doesn't matter what tune you are coming from or to.
WoodBoy is offline
post #7 of 8 Old 02-19-2014, 05:39 PM Thread Starter
With the Spartan from what I've gathered with reading and talkin to the guys that it the 210 race and under is so much like stock that the relearn was next to nothin. I honestly couldn't tell the slightest difference in shifting. The 210 tow tune and up have much firmer shifts so the relearn process quite a bit different and doin the trans relearn is a must.... If that makes sense? But I do understand when you load a new tune it does relearn
2010 F250 CCSB
06psd6.0 is offline
post #8 of 8 Old 02-24-2014, 06:26 PM
SD350's Avatar
I'm not sure what you're towing, but i find that if i use the 275 my foot starts bouncing when the trailer hits bumps. That and cattle move around like water so its hard to maintain a steady throttle with such a touchy tune. I always load the 210TP tune for that reason alone when pulling. Only takes 10-15 minutes.
Cant say that i've ever loaded the regular 210, i never thought the shifting was that bad on the 275.
2008 F350 FX4 King Ranch CC SB
Spartan 275 and 210 Tow as main tunes, AFE CAI
+ Spartan =
SD350 is offline
