Oil Additives - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-16-2014, 06:26 PM Thread Starter
TwinTurbo6.4's Avatar
Quoted: 80 Post(s)
Oil Additives
Anyone run oil additives? If so what brand/type do you go with?
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
post #2 of 11 Old 02-16-2014, 06:29 PM
X-1r
will work with any fluid p/s, atf, gear oils, engine oil
POWER-STRUCK is offline
post #3 of 11 Old 02-16-2014, 07:21 PM Thread Starter
Quoted: 80 Post(s)
Hm, did some looking at that stuff. How much should you add?
'08 F250
post #4 of 11 Old 02-16-2014, 08:04 PM
2 ounces per qt the first time in the motor. 1 oz per qt there after.
1 oz in power steering
4oz in trans
4 oz in rear diff
1 oz in a/c
1 drip in each pulley bearing
1 oz per qt of hydraulic oil in a tractor
Mixes with any oil
And it works well
Power-Struck dot com
post #5 of 11 Old 02-17-2014, 04:09 AM Thread Starter
Quoted: 80 Post(s)
Awesome. I'm gonna order some and see how it goes. I appreciate it.
'08 F250
post #6 of 11 Old 02-17-2014, 06:35 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
check out archoil additives.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 11 Old 02-17-2014, 06:52 PM
Opti-Lube.
Truely amazing
GSchretter is offline
post #8 of 11 Old 02-23-2014, 05:13 AM
colfaxent's Avatar
I use BG DOC , Diesel Oil Conditioner. BG offers a full line of products for all the fluids on your trucks. They have the R&D and their products work. I am no chemist but an oil additive that works in all oils doesnt make sense to me, it obviously must work for anly a few issues. Each fluid in out trucks has a complete set of parameters, benefits and Additive package in them so it sees hard to have a fits all conditioner.. Just an observation. Check out bgprod.com for details.
2009 F350 Crew Cab
H&S Black Maxx Tuner
S&B Intake
2010 Cameo 36FWS 5TH Wheel
Hellwig Sway Bar
MBRP Cold Side Pipe
Closed system CCV mod
5160 Bilstiens x4
Icon 2.5 Front springs
PMF Floating Traction blocks and bars.
PMF Dual Steering Stabilizer
colfaxent is offline
post #9 of 11 Old 02-23-2014, 07:51 AM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
This is what I use too. I asked the bg guy about the diesel oil they have and there trucks that come to use use it each having over 500,000 miles and run perfect. Proper maint goes along way. He is looking into 5w40 syn for me.
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #10 of 11 Old 02-23-2014, 08:19 PM
I run the BG DOC as well.
2010 F250 Harley Davidson. H&S Mini Maxx Race, MCC, 5" down pipe back SS straight pipe, S&B intake, Snow Performance water/meth, FASS fuel pump, Sinister EGR delete, elbow & CAC pipe, Sinister filter housing caps, Bak Industries F1 tonneau, 295/65/20 Nitto Trail Grapplers, Detroit Truetrac (in box for now), lots of lights!
highup0 is offline
