Help!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-11-2014, 04:45 PM Thread Starter
CascadeFord's Avatar
Help!!!!!!
Just plugged in my spartan and loaded the 210 tune. Now the tuner is saying to start the truck but I haven't deleted the dpfor egr yet. Guy from Spartan said I couldn't touch any exhaust components until I loaded the tune. Do I just shut the truck off and get to work ???? Or do I follow the instructions, I know I can't start the truck with a dpf off tune loaded and the dpf still on the truck.
CascadeFord is offline
post #2 of 8 Old 02-11-2014, 05:18 PM
bentstroke_02's Avatar
just start it
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #3 of 8 Old 02-11-2014, 05:19 PM
It wont run long enough to hurt it. Also you could of done exhaust first then loaded the tuner on it and that would of been just fine
Jeremiah
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
post #4 of 8 Old 02-11-2014, 06:05 PM
Just safer to make sure the tune loads up first before you pull the exhaust. That way you'll still have a drive able truck if the program doesnt load properly. Just start make sure its running. Then shut her down and pull the exhaust.
2008 Ford F-350 CC/LB 4X4
Hoosierdiesel is offline
post #5 of 8 Old 02-11-2014, 06:46 PM
B585Ford's Avatar
What everyone else said.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #6 of 8 Old 02-12-2014, 02:22 AM Thread Starter
We'll I wasn't sure so I erred on the side of caution and just shut the key off and went to work. We've been working on the egr delete though and haven't touched the exhaust yet. What do u guys think about me firing up the tuner and truck after finishing the egr setup to make sure my tune loaded before busting into the exhaust?
post #7 of 8 Old 02-12-2014, 05:13 AM
If you've already got the egr done then it doesn't matter. Do the exhaust then worry about it. With the egr gone the truck won't run right on stock tune anyway
2006 F250 EC/SB - SOLD
2010 F250 CCSB
Spartan, 5" dp back exhaust, s&b intake, fuel boost 18x9, 315/70r18 toyo mt
06psd6.0 is offline
post #8 of 8 Old 02-12-2014, 05:29 AM
Sam Hain's Avatar
If you loaded the tune first and it installed successfully then you can delete the egr and the dpf then start it. Thats what I did.
Sam Hain is offline
