Tuner without deletes? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-11-2014, 11:37 AM Thread Starter
hoofdoctor's Avatar
I'm sure this has been discussed in other threads but I'd like an unbiased opinion on running a tuner without doing deletes! The reasoning behind no deletes is I don't want to get into changeing from stock to deletes and back if and when they start cracking down on emissions. Also, my 2008 6.4 runs like a swiss watch and does regens without any ill side effects.
I will be towing a 3 horse gooseneck (about 11,000 pounds) off and on. My main reason for a tuner would be a little more HP increase for towing and better all around fuel economy.
1. Does the fuel (MPG) increase?
2. Is there a noticeable improvement in power and towing/shifting?
3. What would you recommend for a tuner and tunes without breaking my bank account? I've been looking at the SCT SF3 3015
hoofdoctor is offline
post #2 of 15 Old 02-11-2014, 11:48 AM
WoodBoy's Avatar
I drove a 2010 450 for a while with Spartan on the 150 hp on road tuning. There was no improvement in mpg. There was a pretty big improvement in power and towing.
I would not recommend buying a tuner and running on road tunes though unless you are just doing it to get by before you delete. The dpf is too prone to clogging up and causing more problems. I just ordered a dpf-r today for a guy who has been running a tuner for a while and now his dpf is clogged up
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 15 Old 02-12-2014, 03:19 AM Thread Starter
hoofdoctor's Avatar
I'm leaning more towards doing the deletes now. The more I read the more confused I get!
post #4 of 15 Old 02-12-2014, 03:36 AM
I ran my h&s in street until my warranty expired. Mpg increase was negligible. Regents were twice as frequent.
I deleted as soon as the warranty was up and should have done it sooner. There's is nothing to be confused about - the system design is awful. If I lived in emission states I would just spend 2 hours once a year dropping the Dpf and reinstalling to meet the test.
seafordguy is offline
post #5 of 15 Old 02-12-2014, 05:46 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
yeah there wont be any mpg gains because the added soot from more power is gonna cause alot more regens so you may actually see mpg's go down. if i were you id get a dpf delete/cat delete pipe because i can swap a dpf section quick. so if needed you can throw it back on there for emissions. i can have my 5" off and dpf and stock tailpipe on in an hour and a half.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #6 of 15 Old 02-12-2014, 05:57 AM
hansel's Avatar
Quoted: 100 Post(s)
These new exhaust systems are doing more damage to an engine than they are worth IMHO, the 6.4L get horrible fuel mileage because of the regen process. My brother who own's a Chevy 2500HD with a Duramax is actually waiting for his warranty too run out so he can delete his truck and tune it, and then I've heard that the fed's want too make it illegal too purchase delete kit's so I told him he needed to buy his stuff now before he can't.
I'm lucky I have the old 7.3L so no regen or emission too deal with.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #7 of 15 Old 02-12-2014, 07:13 AM Thread Starter
hoofdoctor's Avatar
Okay, so now question 4!
4. What is the most economical way to do a tuner, and egr/dpf delete with the pipe? I don't need anything hot, just looking for better performance and reliability with MPG increase...........Not trying to be cheep but I have a wife that I know won't understand my next move!
post #8 of 15 Old 02-12-2014, 07:30 AM
travisH3's Avatar
Quoted: 2 Post(s)
You may look into dpf-r. I haven't used one personally but the latest one is supposedly works perfect. They sell one that just allows for dpf/egr delete with stock tuning or one that has a slight performance boost. That would be your cheapest route. Only thing with using those is you have to remove the sensors out of the dpf and keep them plugged in where spartan and h&s you can unplug the sensors and leave them in the dpf when you take it off.
T-rav
2010 F350 6.4-
travisH3 is offline
The Following User Says Thank You to travisH3 For This Useful Post:
hoofdoctor (02-12-2014)
post #9 of 15 Old 02-12-2014, 08:51 AM
Sam Hain's Avatar
SCT requires sensors plugged in to, fyi if you go that route.
Sam Hain is offline
The Following User Says Thank You to Sam Hain For This Useful Post:
post #10 of 15 Old 02-12-2014, 09:45 AM Thread Starter
hoofdoctor's Avatar
Reading up on all this egr dpf delete stuff. Should just stop reading and set the hook before it drives me crazy!!!
