DPF, CAT & EGR Deletes - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 21 Old 02-11-2014, 08:35 AM Thread Starter
I know there are hundreds if not thousands of threads regarding this subject, and I've done a fair amount of reading through them, now I have some questions as it relates to my truck.
First off I'm new to the forum so thanks for an awesome site and great information
Purchased my truck about a month ago and has an Edge Evolution, Banks ram air and aftermarket exhaust, dpf back(appears to be 4 inch).
Looking at doing the deletes and a spartan tuner.
Questions I have:
Can I utilize existing exhaust or is it going to be too hard to join the race pipe to existing piping?
Will I notice better MPG with these deletes and Spartan?
Is EGR delete worth it? I know there are many different variations of kits.
Lastly, Is it worth replacing the Downpipe?
Not trying to make a race truck out of it, like the extra HP for sure but the ultimate goal is to keep good driveability and maximize MPG(when I'm not getting my foot into it
Thanks again for the help and sorry for so many questions.
Blown99 is offline
post #2 of 21 Old 02-13-2014, 10:07 AM Thread Starter
So I've done more research and I think I'm going with H&S and race pipe. Haven't decided on egr delete or not. How important/necessary do you guys think it is?
Quote of the Year:
Originally Posted by strokinpower View Post
I would rather sand paper the a$$hole of an alligator inside a telephone booth than do it again.
Blown99 is offline
post #3 of 21 Old 02-13-2014, 05:39 PM
DPF and EGR fast as possible.
I blocked my EGR off at 20k and I don't idle unless stuck in traffic and I had about 1/4 inch thick of soot in my air intake when they removed the EGR to show how had his crap get stuck in theses.
GSchretter is offline
post #4 of 21 Old 02-13-2014, 05:40 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Looking at doing the deletes and a spartan tuner. Both Spartan and H&S are great tuners
Questions I have:
Can I utilize existing exhaust or is it going to be too hard to join the race pipe to existing piping? Yes. basically the race pipe is just the forward part of the full pipe that the previous owner didn't buy.
Will I notice better MPG with these deletes and Spartan? yes. you will see better MPGs... but take this with a grain of salt. Higher tunes will give you higher MPGs ON THE HIGHWAY. In town you won't see a ton of improvements. you are after all trying to get a 4 ton truck moving. Also if you can't keep your foot off the fun pedal you won't get better MPGs (and believe me, once its tuned this is harder than you can imagine... it is a ton of fun to surprise mustangs and other such sports cars).
Is EGR delete worth it? yes. some time you have an hour or 2, take the EGR valve intake off your intake manifold (I believe you can get it off with just a few bolts) and look into your intake manifold. you will notice it is caked in carbon that has been recycled into your engine from your exhaust. if you can't do the full delete, do the block off plates. But if you can I would still try to eventually plan on the full delete.I know there are many different variations of kits.
Lastly, Is it worth replacing the Downpipe? Yes. look below for how constricted the stock downpipe looks. It will clear up some of your exhaust and drop your EGTs a little bit.
See above comments
ccdemo71 and Lilneill6.4 like this.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #5 of 21 Old 02-14-2014, 07:28 PM Thread Starter
Originally Posted by CountryAggie View Post
See above comments
Thanks a lot for the info!!
I just had the emissions done so I'm good for 2 years, so I'll certainly do the turbo back race pipe. As for the EGR, I'm not sure if that is included in the emissions test?? If so I dont think I want to mess with that install every 2 years .
Maybe just do the block off plates and turn it off in the tuner, sufficient?
Blown99 is offline
post #6 of 21 Old 02-19-2014, 07:19 AM Thread Starter
I plan on ordering Race pipe, EGR Delete, CAC pipe and H&S. Seems everyone recommends Rudys? Best price and good support?
Blown99 is offline
post #7 of 21 Old 02-19-2014, 08:19 AM
Sam Hain's Avatar
Rollin smoke diesel have good prices and excellent service too.
Sam Hain is offline
post #8 of 21 Old 03-05-2014, 11:06 AM Thread Starter
What to expect
Ordered Mini Maxx, DPF/Cat delete and also EGR Delete. I have read as much as possible, watched videos on installs, read install directions etc.
What else should i expect? Any crazy tips? I may not install the EGR delete at the same time, can I do everything else and tell the Mini Maxx not to disable the EGR yet?
Not worried about the physical installs, just want to make sure I do everything right on the Mini Maxx, which may be super easy and walk me right through it but just dont know yet......
Just want to make sure when I go to do all this I'm not stuck wishing i had asked more questions or waiting on answers!
Thanks again.
Blown99 is offline
post #9 of 21 Old 03-05-2014, 03:06 PM
StrokiNDieseL's Avatar
install minimaxx 1st, this make sure truck loads tuner w/o any troubles. it will ask if emissions are present, answer correctly if emission are present!
Once you do deletes re-tune it & go load process again & answer questions correctly! Always remember EASY tune cycles the EGR systems, If its removed DO NOT USE EASY tuning. Good luck, Jayson.
Lilneill6.4 likes this.
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #10 of 21 Old 03-05-2014, 05:04 PM Thread Starter
Thank you for the info! When the Maxx asks if emissions are present is it strictly referring to EGR or is there a subset of questions following to choose EGR on/off and DPF on/off?
Quote of the Year:
Blown99 is offline
