Tuner / DPF Delete - From Dealer - Ford Powerstroke Diesel Forum
Old 10-26-2008, 05:56 AM
Is there anyone out there that the dealer has installing a tuner and delete pipe and still is keeping the warranty? I heard that dodge is doing this because a tuner and delete is cheaper for Chrysler to buy than to keep replacing turbos.
I will be buying a 08 F350 King Ranch LWB within a month and was wondering if anyone has had this done yet.
Thanks for input in advance.
Old 10-26-2008, 08:24 AM
I remember reading on here a while back about a dealer out west thats selling superdutys with tuner and dpf delete. I'm first in line if I find one
Old 10-26-2008, 10:18 AM
I know my dealer in edmonton,ab does it. The kit is a DPF delete kit and only eliminates the regen (no power gains). They only do it if the truck is used in the forestry industry as far as i know.
Old 10-26-2008, 11:02 AM
Does this delete your dealer provides greatly increase MPG? And how are they when it comes to warranty work?
Old 10-26-2008, 11:20 AM
i doubt there is alot of dealers out there that will put on the dpf delete. but there are some that will warranty your truck if you have the the delete. kenny vice in lagota, indiana will warranty your truck with a dpf delete and tuner.
Old 10-26-2008, 11:23 AM
i'm honestly not sure. They said they install it for forestry applications due to the high risk of fire from the excessive heat generated by the regen on the 08+ 6.4L. Either way, I'm not in forestry so they wouldn't do it. I bought a delete kit from BADP. I have their tune and a SCT livewire. Either tune gains me approx 45-55 miles more per tank. (Job 1 truck). As for warranty work, I put the DPF back on and flash it back to stock. No questions asked thus far.
Old 10-28-2008, 02:29 PM
So, there is a way to just put the delete pipe on and reprogram the computer to stop regen without having to put in a fully functional tuner? I read the 50 page thread about just taking the dpf and cat off and obviously that doesn't work. I'm not wanting to upgrade the power and mess with all that stuff because I'm going to be using it for towing quite a bit and I want the engine to last for a long time, well...for atleast as long as I can afford fuel. Does anyone know how to reprogram the computer to just stop the Regen?
Old 10-28-2008, 03:29 PM
PowerStrokin!!!!
even tho some tuners are expensive, companies like sct have stock tunes on there modules with the dpf delete option, then u also have the ability to get the H @ S delete module that plugs into your obd 2 port or the hard wire version. im not sure how good the H@S system is but i have seen there 08 in person with there delete pipeing a module and it looked like it ran mighty fine to me. www.dieseltruckchips.com
Old 10-28-2008, 04:02 PM
Cam Clark in Airdrie AB is a tuner/No DPF friendly Ford dealer, If I ever buy a new truck its threw them.
Have gone out of there way for me and my wife's fords.
