Dpf delete options. - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 02-07-2014, 05:40 AM Thread Starter
xxxjagsfanxxx's Avatar
Send a message via AIM to xxxjagsfanxxx
Dpf delete options.
Recently moved to a new area and bought a 6.4. Truck is completely stock now and I wanted to do egr/dpf deletes, intake and a dp back exaust with a spartan programmer. Well I recently found out that I now live in an e-check county and have to pass emissions check ever year to renew my plates. My thought was to make it simple, just do everything as planned. But only remove the dpf and leave the rest of the factory exaust. Then once a year replace dpf and remove tuner. Just was curious of anyone has ran a factory exaust with just a dpf delete. How did it effect fuel mileage, performance, etc. thanks guys.
Sent from AutoGuide.com App
[COLOR="Red"][SIZE="2"]2002 F-350 ext. cab long bed 4x4
4 inch turbo back exaust with 6 inch miter cut stacks
isspro guages(boost and pyro)
S&B intake
boost fooler
TW 6 position chip
bd diesel turbo timer
8 inch lift
38x14.5x17 goodyear wrangler MT/R's
xxxjagsfanxxx is offline
post #2 of 14 Old 02-07-2014, 05:45 AM
Sam Hain's Avatar
I would just buy a race pipe, remove CAT/DPF in one piece. Leave sensors hanging (zip tied) then we renew time comes around remove 2 bolts and loosen the back clamp near muffler and put the emissions junk back in. The hardest part of the whole process is making sure you don't booger up the 13mm nut that screw the sensors in the dpf. PB blaster is your friend.
Sam Hain is offline
post #3 of 14 Old 02-07-2014, 08:10 AM
WoodBoy's Avatar
Definitely easier to do as Sam stated and remove the dpf/cat as one piece
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 14 Old 02-07-2014, 11:23 AM
sandpiperx1's Avatar
can the dpf be removed and not the egr? will the egr be turned off with the tuner?
2010 F-350 King Ranch 6.4 Diesel fully deleted and in custom mod mode. weekend and trip beast
2009 F-150 XLT Gasser 4.6 3 valve. my company truck. daily driver
2013 BMW 328I modding in motion.
Blueskyglassdesign.com
sandpiperx1 is offline
post #5 of 14 Old 02-07-2014, 11:42 AM
Sam Hain's Avatar
Yes, tuner can turn off egr but coolant still flows thru them. To stop that and leave them in place you would need block off plates.
n_bigras likes this.
Sam Hain is offline
post #6 of 14 Old 02-07-2014, 12:00 PM
Sam Hain
then one more thing not trying to hijack. is it worth the effort to remove both the dpf and the cat or just leave the cat? what effect either way will this have .
m
post #7 of 14 Old 02-07-2014, 12:03 PM
Sam Hain's Avatar
Alot easier to remove CAT/DPF all in one piece. Only remove 2 bolts and loosen 1 clamp. If you leave CAT on theirs approx 18 nuts to remove DPF from CAT.
Sam Hain is offline
post #8 of 14 Old 02-07-2014, 12:07 PM
WoodBoy's Avatar
Just to clear this up. Block off plates do not stop the flow of coolant through the coolers. They just go at each end of the coolers to keep the exhaust flow out of them
WoodBoy is offline
post #9 of 14 Old 02-07-2014, 12:07 PM
Appreciated Sir. that is the kind of info that is needed to do things right the first time. Thanks you for your time.
I am back Quiet. m
post #10 of 14 Old 02-07-2014, 12:09 PM
Sam Hain's Avatar
Correct, I got my words a little tangled up
Sam Hain is offline
