DPF/CAT delete pipe
does anyone have any suggestions on how to get powerstroker67's pipe in on the muffler side? i have someone who is having some problems. 3 1/2 stock exhaust but it does not seem to want to slide in....any suggestions???
you can beat it in there but then you are not able to turn it to match up with the downpipe...anyone....
Have you tried a ratchet strap puling from the back of the truck?
I am the guy with the problem. I am not sure how the ratchet strap would work. I can beat it in there but can't turn it to match the down pipe. I can't turn it initially and then beat it in because the belled out side catches on the down pipe. With what i have the only way i can install it is to slide it in and then turn but the tolerance makes it turning impossible.
spread apart the cat back exhaust where the strap goes around the pipe. i just used a pipe and put it inside and pulled till i spread the sides of the pipe enought to get the pipe in side. I hope this made sense.
Kevin |
One thing to note- I've always found they install much easier by taking a hammer and lightly beating the "Lip" of the pipe on delete pipe, toward the tailpipe end, in a bit.
In other words, on the leading edge of the rear end of the delete pipe- beat lightly with a hammer all the way around. Many times the ends come out with a slight "bell shape" from the forming and crimping, which can make it a pain to install. |
Just installed mine this last weekend. Thanks. Man this truck is SOOOO fun now! ![]() |
JBHT- How did you do it? I have removed the CAT and DPF without a problem. Now I have the downpipe with flange on one end and the 3-1/2" slotted female pipe with clamp on the otherside. Trying to fit powerstroker67 pipe in there has been a chore! What side do you bolt up first? Do the nipples and pressure bracket face up? Did you remove the factory muffler and tailpipes?
