Dpf delete only - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 02-03-2014, 05:40 PM Thread Starter
Dpf delete only
Just installed dpf delete pipe left the doc on. It was very easy (bought new egt sensor & gasket). It sounds good and seems to run better. I was just concerned about the doc. Will it clog up and how would I know ,if the dpf-r turns off emissions system would I get a cel code?
Adam1976 is offline
post #2 of 13 Old 02-03-2014, 06:24 PM
WoodBoy's Avatar
No it ain't going to clog up and if it wasn't working you would have signs especially if it went into regen
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 13 Old 02-03-2014, 06:32 PM Thread Starter
But it can't go into regen mode because the dpf-r tunner turns it off allowing removal of the dpf
Adam1976 is offline
post #4 of 13 Old 02-04-2014, 05:26 AM
WoodBoy's Avatar
Well then that would mean it is working right??????
BurTronn likes this.
WoodBoy is offline
post #5 of 13 Old 02-04-2014, 05:31 AM
TwinTurbo6.4's Avatar
Quoted: 80 Post(s)
Planned on doing the DPF delete next month. I guess I didn't do it soon enough. Truck shut off and would start, then I had to get it towed to the dealership to find out that a sensor isn't covered under warranty. Ended up being $1200 in parts and labor for a dang sensor.. not to mention I had the truck for 3 months now and they couldn't work with me at all. Last time that dealership will get my business..
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
post #6 of 13 Old 02-04-2014, 06:17 AM Thread Starter
Get rid of the dpf you won't regret it truck feels much stronger and breaths better
Adam1976 is offline
post #7 of 13 Old 02-04-2014, 10:06 AM
WoodBoy's Avatar
What sensor? Why would you even pay that? I would have paid the tow bill and told them to shove it. Any of the three dpf sensors are around $60
WoodBoy is offline
post #8 of 13 Old 02-04-2014, 10:11 AM
Quoted: 80 Post(s)
Beleive me, it was unexpected and I gave em hell. They tried to tell me the code P2002 was a bad DPF system all together. I have an aftermarket intake causing that.. ($2700 to them) The parts manager is probably glad i'll never go back there. They said they ran into corrosion with the sensor which caused an excessive amount of labor. But $1200 my
'08 F250
post #9 of 13 Old 02-04-2014, 10:32 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Sometimes the sensors can be a doozy if the tech stripped the head the dpf has to come off so they can drill and tap it. If you get under the truck you should be able to tell if they had to remove the dpf. The bolts will tell you if they removed it. If not I'd have to go back to the dealership. When replacing the sensor it's pretty easy cuz you get to cut the wire and you can get a box end wrench on it so you don't strip it. I usually just hit them with pb blaster a couple times and then use a good pair of channel locks when I have to reuse the sensors. I did a dpf-r on a 6.4 and got all 3 sensors out of a 170k mile truck without much hassle. I was surprised.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #10 of 13 Old 02-04-2014, 11:05 AM
Quoted: 80 Post(s)
I've been looking into this hidden EPA emissions warranty. Its 8 year/80,000 mile warranty covered by the EPA. I'm wiggling around there to see if I can get anything.
I guess its safe to say if they took it down, putting the delete on will be easy.. (trying to be positive. )
'08 F250
