Mild Build - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 116 Old 02-03-2014, 03:28 PM Thread Starter
groove's Avatar
Mild Build
Well, thought I might document my build.
Parts are on order, so it should be updated fairly regularly.
Started with 08 F350, 260000km. Got a good deal on the truck but knew it needed some work. Lots of smoke, blow by and oil consumption.
Tore it apart and broken rings on #2, #3 and #5 cylinders.
Heads look good, sent them out for some re/re work and the block is at the machine shop getting ready for some 0.030" over de-lipped OEM pistons.
Will update as the parts arrive and I begin to assemble
Goal is a nice reliable DD truck I can stomp on once in a while.
Cheers
GSchretter likes this.
08 F350 CCSB 4x4 01/07 Job 1
0.030" de-lipped slugs, 70+ atmosphere turbo, ARP studs, Mild Ported Heads (w/bronze guides), Flo-Pro EGR Delete
Mini Maxx Race tuner, AFE exhaust turbo back, S&B Intake, Sinister coolant filter
Lifted nicely on 20" wheels
groove is offline
post #2 of 116 Old 02-03-2014, 05:39 PM
Post pics if possible
GSchretter is offline
post #3 of 116 Old 02-03-2014, 06:40 PM
B585Ford's Avatar
Cheers
Since reliability is your goal, I will skip the go fast parts. You might want to consider doing a thermal coating on the pistons. If you aren't deleted, I would definitely do that. Finally, I would at least do some 6.0 exh mannies and some upgraded up pipes.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #4 of 116 Old 02-04-2014, 06:26 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Also throw on a ported intake manifold while your at it. I am looking forward to the build. Good luck
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 116 Old 02-04-2014, 09:10 AM
WoodBoy's Avatar
I don't see the need in coating the pistons with them being de-lipped but that's just my opinion
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #6 of 116 Old 02-13-2014, 04:25 PM Thread Starter
groove's Avatar
New 0.030" delipped pistons arrived today. I think I will touch up the machine work a little and then we can get on to the fun stuff!
groove is offline
post #7 of 116 Old 02-13-2014, 08:17 PM
B585Ford's Avatar
Them's sexy...they did a good job on delipping them.
B585Ford is offline
post #8 of 116 Old 02-13-2014, 08:24 PM
srjd's Avatar
Quoted: 2 Post(s)
Pardon my ignorance but what is de lipping and what are the benefits
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #9 of 116 Old 02-14-2014, 02:25 AM
B585Ford's Avatar
Look at a pic of the factory pistons. The top of the piston has a smaller hole than the bowl of the piston. The metal on the top of the piston that hangs over the bowl is the lip. The metal there is thin with a pointed edge so it collects heat. That is where a lot of pistons start to crack.
B585Ford is offline
The Following User Says Thank You to B585Ford For This Useful Post:
StrokiNDieseL (02-14-2014)
post #10 of 116 Old 02-14-2014, 01:51 PM Thread Starter
groove's Avatar
Overall the de-lipping looks good. There is a very slight ridge on a few about halfway down the wall that I think I will polish up before install. Still have a few days before the machine shop is done with the block. Aiming for 0.0025" piston to cylinder wall clearance. Ford spec is 0.0018" - 0.0037"
groove is offline
