Sure its a dead horse but lets beat it again!! Mini maxx- what do yall watch and why? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-01-2014, 08:31 PM Thread Starter
Shauny2times's Avatar
I find myself watching this mofo like a HAWK! I got pyro 1, boost, oil and coolant temp--making sure the oil cooler is acting right and those two stay close, but theres so many options so was wondering what else i may wanna peek at and how come... Thanks yall
Shauny2times is offline
post #2 of 15 Old 02-02-2014, 03:48 AM
Pyro -
Tranny - I try not to give it more than 15-20%throttle until it is in the 160 range
Throttle Input - like to see how hard I am in it
Coolant - have defuel set at 170 but don't normally give it more than 15-20% throttle until it is in the 190 range
seafordguy is offline
post #3 of 15 Old 02-02-2014, 05:58 AM
floorboy's Avatar
Boost
Pyro
Coolant
Ebp
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #4 of 15 Old 02-02-2014, 08:01 AM Thread Starter
Why ebp? Whats a good or bad range ?
post #5 of 15 Old 02-02-2014, 08:27 AM
Quoted: 48 Post(s)
I don't even leave mine in my trucks anymore.
I run them when I go to the mountains or to diagnose issues or dial in my custom tunes.
When I used to leave them in the trucks all the time, my four were Pyro, boost, ECT, EOT
drunk on diesel is offline
post #6 of 15 Old 02-02-2014, 08:39 PM
B585Ford's Avatar
EBP will be higher than boost almost all the time. With a high enough EBP, you can float a vavle. In reality, boost gives you an indirect look at your HP and the more HP, the more chance you have at blowing a HG and up pipes (maybe pistons), but with a 6.4 with the normal mods, you are more likely hurt your engine with higher EBPs than boost. Of course, EBP is major factor in how much boost you are running (along with vanes on the VGT turbo). On a stock valvetrain, I wouldn't want to see over 70. Depending on how conservative you want to be (in other words how much risk you are willing to take of hurting the engine), you might want to try to keep it below 60 (that is a very conservative number). Dont worry about your boost to EBP ratio when you are just taking off, but if you are at WOT, a 1: to 1.5:1 ratio would be desired. Also keep in mind with EBP, the H&S monitor gives you the actual value but with Spartan (a DD made by Drew Industries) the reading is absolute so with Spartan, you have to subtract roughly 14.7 from the value you see for EBP depending on the barometric pressure where you are at.
The other thing I would recommend monitoring from time to time would be ICP. That is your RP. If you are running your truck at WOT, your RP should be around the mid-20k range (depending on the tune). If you find your desired RP is a few thousand higher than your actual RP, you are having some kind of issue on the fuel side of things....the most common problem would be your HPFP is getting weak.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #7 of 15 Old 02-02-2014, 09:49 PM
Pyro
Coolant temp or ebp (I switch it once and a while)
Ipw
Rail pressure
o4ep3civ is offline
post #8 of 15 Old 02-03-2014, 01:28 PM
floorboy's Avatar
I use my EBP (lately) to monitor the freezing up of my sensor. If it quits moving it's freezing up.
floorboy is offline
post #9 of 15 Old 02-03-2014, 01:34 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
lets beat it again
didn't your momma tell you you could go blind doin that?
sorry I'll go back to my corner now
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #10 of 15 Old 02-03-2014, 04:27 PM
pops250's Avatar
Lol thats funny.
H&S tuned. B&W gooseneck hitch with Companion 5th wheel. Helwig rear sway bar. Edge CTS monitor. Dieselsite coolant filter. Rancho 9000 shocks. Airlift 5000 air bags with onboard compressor. Viair onboard air with 5 gal tank. Flo-pro stainless 4 in. exhaust.
pops250 is offline
