Head stud question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-31-2014, 11:09 AM Thread Starter
Head stud question
so i would like to install head studs in my 08 6.4 to increase the reliability and not be one of those guys wishing i had spent the money on head studs. i have seen a few threads where guys have installed them without removing the cab, replacing them one at a time. my question is does this fix the head bolt problems with the 6.4? would installing studs this way actually prevent problems or is it necessary to pull the heads and replace the gaskets (i currently have no problems indicating bad head gaskets). if i am going to spend $500 on a set of studs i want to make sure they are doing what they are supposed to. i currently have no place to pull the cab myself so if i had to go that route it would get costly rather quickly...
i will soon be installing a DPF delete and sct tuner but plan on only using a mild tune. i dont do much towing the truck is mostly just a daily driver
georgiaboy1491 is offline
post #2 of 4 Old 01-31-2014, 11:24 AM
WoodBoy's Avatar
There are people who have done them one at a time, then out of those, you got those that had problems, and those that are still going strong. So you may do them one at a time and never have a problem or you may end up like some of the others who have had to pull the cab and either magnaflux and resurface their heads or buy new heads.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 4 Old 01-31-2014, 03:17 PM
B585Ford's Avatar
Exactly what he said. Some have no issues and others do and that is from people who never had any known HG problems. If you do it yourself, make sure you have your torque wrench calibrated and make sure you don't over torque your studs on cylinder 1 and 2.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #4 of 4 Old 02-03-2014, 04:02 PM
XPLOSIV's Avatar
My mechanic said not to do them unless I'm running crazy power.
08 F450 CCLB 4.30's
Spartan, Pure Performance Custom 3", Toyo M608Z, MBRP, FloPro, Banks, Volant, Mishimoto, Dieselsite, LineX, Reese 30k
XPLOSIV is offline
