egr tuner deletes - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-31-2014, 10:35 AM Thread Starter
egr tuner deletes
has anyone used the h/s tuners to turn off the egr and not remove any parts
wondering if this option was safe v/s removing the coolers and blocking them off.. should be the same effect but was not sure of any side effects of leaving the junk on and disabling the valve.. thanks
4wheeldady is offline
post #2 of 4 Old 01-31-2014, 11:00 AM
Sam Hain's Avatar
Your better off completely removing the coolers for the long haul, on the cheap you can put the block off plates in.
Sam Hain is offline
post #3 of 4 Old 01-31-2014, 11:29 AM
WoodBoy's Avatar
Pretty much all tuners turn of the EGR whether in place or not. Spartan lets it cycle on some tunes below the 275 at idle, and then some of the even lower tunes cycle like a normally stock truck would. Then they have their tunes you can download that all tunes keep the egr turned off. Anyways, it is very common to keep running the with the EGR in place. I did for a while under warranty, but coolers can still fail even though the valve is off. I recommend deleting the coolers and replacing the valve/elbow with an aftermarket elbow
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 4 Old 01-31-2014, 11:31 AM
Quoted: 48 Post(s)
I wouldn't worry about it. seen plenty of trucks over 200k with untouched EGR equipment
drunk on diesel is offline
