6.0 manifolds - Ford Powerstroke Diesel Forum
post #1 of 18 Old 01-30-2014, 06:12 AM Thread Starter
6.0 manifolds
truck is going in for studs and I plan to change the manifolds to the 6.0 and modified up pipes while the cab is off. I was looking at an elite setup but also considering getting used 6.0 manifolds from the shop where i'm taking it.
is it worth the extra money to get the coated ones from elite over used ones?
what else is needed besides up pipes if I go with used manifolds?
is it worth the $225 to have the up pipes coated also?
trying to get all my ducks in a row before I take it in, trying to take care of some of the more common problems while the cab is off. truck is at 120k mi, h&s tuned with 5" flo pro down pipe back, and s&b intake. I'm one of those lucky ones that run low power tunes and didn't hot rod it and still had the head gaskets go.
pan4905 is offline
post #2 of 18 Old 01-30-2014, 06:27 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I got a used set of Rudy's up pipes from a member on here. I also got the 6.0 manifolds from the same member. My manifolds are not coated. If you have the time and the money it is probably worth it. All you need is the up pipes and the manifolds. They bolt right up.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 18 Old 01-30-2014, 06:28 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
By the way the 6.0 manifolds make the 6.4 sound bad a$$!
08 F350 cc/sb 4X4
post #4 of 18 Old 01-30-2014, 06:31 AM
Quoted: 370 Post(s)
Feedback Score: 5 reviews
i'll sell you a set of 6.0 manifolds for $75 plus the ride.
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #5 of 18 Old 01-30-2014, 08:46 AM Thread Starter
Aren't there spacers and/or different bolts, shorter or longer needed also?
pan4905 is offline
post #6 of 18 Old 01-30-2014, 08:48 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yes you need the 6.0 bolts and spacers. You can get them from ford.
08 F350 cc/sb 4X4
post #7 of 18 Old 01-30-2014, 09:03 AM
Quoted: 370 Post(s)
I should be able to include bolts/ spacers... Or at least most of them so you wouldn't need to spend as much at the dealer.
Studded and Deleted
post #8 of 18 Old 01-30-2014, 09:08 AM Thread Starter
Thanks. I'll let you know something shortly once I hear back from the shop.
pan4905 is offline
post #9 of 18 Old 01-30-2014, 09:11 AM Thread Starter
One more thing, gaskets? 6.0 or 6.4 or are they the same?
pan4905 is offline
post #10 of 18 Old 01-30-2014, 09:12 AM
Quoted: 370 Post(s)
You'll probably need some new 6.0 gaskets.
Studded and Deleted
