Issues with SCT 3015R - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-28-2014, 08:22 AM Thread Starter
Sam Hain's Avatar
Tried deleting this weekend and wasn't able to because my tuner wouldn't load the custom file. My tuner is up to date with the latest firmware version and is unmarried with 4 unlocks left. For some reason I kept getting 1017 error Upload stock failed, then 1009 No tune changes. Tried 3 times same result. I spoke with the guy I bought the tuner from and he said he had the same issue and talked to Matt at gearhead and he thought he sent him an updated stock file to load first then reload the custom tune. I also called SCT this morning and they pretty much wasn't any help w/o having the tuner hooked to a laptop, hooked to my truck. I don't have internet at home so if that is the only fixed I'm screwed. Anyone else seen this?
Sam Hain is offline
post #2 of 17 Old 01-28-2014, 08:49 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
It doesn't have to be hooked to a laptop while connected to your truck...
It just has to be hooked to a computer with internet so SCT can access it remotely.
They can fix just about anything remotely...
Otherwise, it will have to be sent to SCT if you have no other options.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 17 Old 01-28-2014, 09:01 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Try going to a library if you don't know anybody that has a computer with internet access. SCT will be able to remotely fix your hand held tuner. How are you able to get onto the powerstroke.org? If its thru a phone you can make your phone a mobile hot spot and allow your laptop to sign online
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 17 Old 01-28-2014, 09:02 AM Thread Starter
Sam Hain's Avatar
I told SCT guy I had tuner hooked up to laptop with internet and he didn't even offer to remote in an check. He said I needed to have the vehicle on hand.
Sam Hain is offline
post #5 of 17 Old 01-28-2014, 09:03 AM Thread Starter
Sam Hain's Avatar
I get on here via my work computer.
Sam Hain is offline
post #6 of 17 Old 01-28-2014, 09:05 AM
dfuzz78's Avatar
They have never told me that, I've had to have it done twice... Once last evening to be exact...
Denis "Lt. Sled"
dfuzz78 is offline
post #7 of 17 Old 01-28-2014, 09:15 AM Thread Starter
Sam Hain's Avatar
Sam Hain is offline
post #8 of 17 Old 01-28-2014, 09:23 AM
dfuzz78's Avatar
He contacted SCT and they accessed it remotely and fixed the issue.
Originally Posted by MONSTER_NRG View Post
Called SCT and they linked into my computer and fixed it. They had to add a file or something.
Denis "Lt. Sled"
dfuzz78 is offline
post #9 of 17 Old 01-28-2014, 10:39 AM Thread Starter
Sam Hain's Avatar
Just got off the phone with SCT and tuner is being reflashed at this moment, hopefully that will cure the issue.
Sam Hain is offline
post #10 of 17 Old 01-28-2014, 10:44 AM
dfuzz78's Avatar
It will work out for ya!
Denis "Lt. Sled"
dfuzz78 is offline
