H&S mini maxx Defuel settings - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 24 Old 01-27-2014, 11:29 AM Thread Starter
oregoncalfroper's Avatar
Quoted: 9 Post(s)
Send a message via AIM to oregoncalfroper
these are the settings that were done when I bought truck I did update yesterday but didn't adjust these. Are some of these pretty conservative?
oregoncalfroper is offline
post #2 of 24 Old 01-27-2014, 12:27 PM
spock91's Avatar
Quoted: 6 Post(s)
Cold Temp looks too low for me......
I run 170 to 180 before the tuning kicks in.
Also my Boost is 36 but I am a wuss...
Spock
spock91 is offline
post #3 of 24 Old 01-27-2014, 12:32 PM Thread Starter
Quoted: 9 Post(s)
what mods on your truck?
post #4 of 24 Old 01-27-2014, 12:41 PM
spock91's Avatar
Quoted: 6 Post(s)
DPF/Cat delete, S&B Intake, H&S Mini Max, Sinister Coolant Filter, MBRP Intercooler Pipe, PTP Direct Drive Solenoid...
Not much
Spock
spock91 is offline
post #5 of 24 Old 01-27-2014, 12:54 PM Thread Starter
Quoted: 9 Post(s)
I'm about the same... s&B, proflo intake elbow, egr's deleted, 5inch exhaust.. I figured everything might be conservative and it looks like it is except cold coolant too low and boost is probably too high
post #6 of 24 Old 01-27-2014, 01:11 PM
spock91's Avatar
Quoted: 6 Post(s)
I have an EGR delete in the garage waiting to get up the nerve to install it.
Hopefully someone smarter than me will chime in with more information.
Spock
spock91 is offline
post #7 of 24 Old 01-27-2014, 02:11 PM Thread Starter
Quoted: 9 Post(s)
mine came as listed but I did add a coolant filter last week, I hope someone else does chime in on this.
post #8 of 24 Old 01-27-2014, 02:20 PM
WoodBoy's Avatar
Only defuel I would run would be the low setting for coolant @ 180 degrees. Maybe the high coolant and oil at 215 and 225. I wouldn't do the rest
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #9 of 24 Old 01-27-2014, 05:33 PM
I run cold coolant at 170. Boost at 40.
I defuel on boost when I'm in it on the interstate with the tc locked up.
I think my pyro is 1400 - I would see north of 1200 on my stock non-deleted truck during regen. These trucks can handle north of 1200 easily
seafordguy is offline
post #10 of 24 Old 01-27-2014, 07:23 PM
I think your cold coolant is too low, your oil temp is low by a tiny bit, and your boost is definitely on the high side. I like my truck to warm up before I give it the juice.
I'd say do somewhere around 160-180 for cold coolant, 220 for oil, and lower the boost a tiny bit (mine is at 44, which is as high as I'd ever want it). Otherwise I think you're in good shape.
B. Adams is offline
The Following User Says Thank You to B. Adams For This Useful Post:
Bdwill (04-08-2016)
