What is the safest/best reviewed tuner? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 01-26-2014, 01:56 PM Thread Starter
I haven't been on here in a while, but back in 2009 everyone was going with the spartan tuner with the dpf/cat delete. Has anything changed since then?
I'm looking to be able to significantly increase my MPG from its current 9 mpg to maybe around 17 or 18. I have a 8 inch lift running 37 inch tires on 22 inch wheels.
I live in San Marcos, so anyone in Central Texas that is known for installing these things well with no issues, pm me.
Thanks for any help, as I'm sure this topic has been covered over and over.
broncoboy7914 is offline
post #2 of 13 Old 01-26-2014, 02:38 PM
WoodBoy's Avatar
Spartan is a good tuner as well as H&S or SCT W/ custom tunes. But if what you are after is in bold, ill just put it like this......
Aint gonna happen unless you are sleeping and dreaming
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 13 Old 01-26-2014, 03:07 PM
Good god, I hope those MPG are towing... I'm getting damn near 15 MPG stock unloaded.
Sideswipe505 is offline
post #4 of 13 Old 01-26-2014, 03:19 PM
Hawkeye Diesel's Avatar
I have an 08 6.4 with 8" lift and 37x12.5 r 20's, running the spartan 210 delete. I get around 13 mpg. I don't know if you'll see much better than that with big heavy tires and a brick sitting 8' up in the air
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #5 of 13 Old 01-26-2014, 03:59 PM
WoodBoy's Avatar
Every tank I average around 13.8-14.2mpg. I'm leveled on 35s. If I get out on the interstate and keep it around 70, no higher than 73mph, ill get around 17.5ish-18ish the whole time on the interstate but I don't drive interstate much
WoodBoy is offline
post #6 of 13 Old 01-26-2014, 04:03 PM
WoodBoy's Avatar
stock wheels and tires?
WoodBoy is offline
post #7 of 13 Old 01-26-2014, 05:36 PM Thread Starter
I'm wanting to tune it bc ill be driving 50 miles there and back Monday thru Friday. I guess I've heard ppl bs all the time about their 17mpg.
But yeah I'm driving a brick so I don't want to put it on if my gains are minimal. Seems ppl have a lot if issues after tuning so I want to stay away from blown engines and everything im between.
post #8 of 13 Old 01-26-2014, 05:36 PM Thread Starter
All on the highway**
post #9 of 13 Old 01-26-2014, 05:56 PM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
17mpg isn't BS with these trucks. But you aren't going to see that with that large of a lift and tires. With all the rolling resistance that the weight of the tires has it will drop your MPGs a lot. And you are driving a truck with the aerodynamics of a bus... worse when you throw it up 8" into the air.
My guess is with the deletes and a tuner you would see 13-15 out of your truck on the highway.
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
post #10 of 13 Old 01-26-2014, 07:25 PM
Yep, and they'll stay that way til I delete/tune the truck.
