EGTs with Intercooler
Was driving from VA to FL at night around 2am and noted the following EGT numbers, each was sustaind for 5 minutes in 72 degree dry temp on flat and straight roads (I95)
MPH EGTs 70 640 75 700 80 700 85 700-740 90 760-800 95 800 Didn't hit 100 due to enough tickets in the past.
Those are some pretty low egts considering the speed. what is the highest temp you have seen @ wot??
1000-1100 on the pyrometer
Yesterday morning cruising to the Nats I was looking at my EGT's, with the 275 tune at 75mph I was seeing about 735-745 degrees
So in regards to that and your posting I still cannot justify the intercooler until something can be done about that upper tube thats crimped...I just feel that its like a nickle holding up a dollar |
I would say that it would be the tire weight adding egts but yall both have larger tires an stock gears so i don't know
