who sells F450 gears? - Ford Powerstroke Diesel Forum
Old 10-05-2008, 12:36 PM
1st post to a great site!
Just purchased a 08 f450, CC DRW 4x4. Love the truck so far. I use it for my roofing business and we tow 8-10k lbs about half the time we drive it. We travel often as much as 200-250miles to the job site, so a lot of highway driving. Ive just installed a 5" DPF back magnaflow exhaust and a Hypertech programmer. And, I've got a Banks intake on order. Future mods may include a DPF/Cat delete and tune (ditch the hypertech). I wonder how much MPG I would gain with that on a drw 4x4?
Is there a supplier for the f450 rearend gears? I have a friend who works for a local truck shop doing nothing but changing rear end gears all day, so I have the labor. Im thinking of switching up the 4.88's for 4.10's.
Opinions/ideas appreciated.
Chris
Old 10-09-2008, 07:36 AM
I also have the same truck as you and looking into putting in 4:10 gears. What I have found out is you don't get the TONE RING with 4:10 gears, this is used for the speed pickup. you would have to take the sender out of the rear end and mount it to the back of transfer case with A 30 tooth spocket on output flange to drive speedo input, I'm working on this part. UNITREX in fullerton ca. has the front and rear gears for about $1000.
Old 10-09-2008, 07:45 AM
Try Randys Ring and Pinion . I have never gotten 450 gears but we use them for almost all of our stuff. They are great people to work with .
Old 10-09-2008, 08:18 AM
Most shops that deal with pickups don't have parts for the dana S110L rear end, you have to go to someone who deals with medium size trucks.
Old 10-11-2008, 10:56 AM
Thanks for your help. I really think getting the RPM down will make a big difference. Im getting 8.5 mpg pulling my trailer at 75, but if I drive 63 I can get 9.7-10.
I just received my DPF delete pipe and tuner. I won't be able to get them in for a week or so. That will help.
Old 10-13-2008, 11:07 AM
Get a gear vendors overdrive unit and then you will still be able to tow heavy when you need to by switching the overdrive off.
