snow performance - Ford Powerstroke Diesel Forum
Old 10-02-2008, 10:35 AM
snow performance
Anyone who has tried the snow performance methanol injection, how does it work? Do you like it? I have heard you can run windshield washer fluid? I only ask because they are offering huge savings this month and i can get a system fairly cheap.
Old 10-02-2008, 10:48 AM
I have the mileage inhancing model and like it very much. I run between 20 and 50 percent methanol and have found mileage increases as much 2 1/2 miles per gallon of diesel fuel. It is a very reliable working device.
Old 10-02-2008, 10:52 AM
whats the deal they are offering this month?
Old 10-02-2008, 10:55 AM
IT's like 15% off or something like that. I think I saw the add in the new diesel power mag. I was curious about this also. I know one of the brands uses cheap hose connectors or something like that but I can't remember which one it was.
Old 10-02-2008, 11:00 AM
If i could pick it up for around 500, i think id pull the trigger. even tho its earlier than i want.
Old 10-02-2008, 11:24 AM
So on the 6.4, do you take off the intake to drill, or where did you install the nozzles?
Old 10-02-2008, 01:25 PM
Project Abused
I didn't take it off, I just left the engine running so the compressed air would blow out the chips. Also i didn't drill into the intake per say I drilled into the cac tube after the cac (pipe that connects cac to air manifold.
Old 10-02-2008, 01:36 PM
You drilled before the rubber boot that connects to the intake? The aluminum pipe coming from the turbo intercooler cac. So I disconnect the pipe via the boot, run the engine and drill and tap the cac pipe, then reconnect the boot to the intake?
Old 10-02-2008, 07:39 PM
did you see any MPG gains when using this setup?
Old 10-11-2008, 02:34 PM
How do I get the special? I am looking at buying and I'd rather have the snow kit but if they aren't still running a special, I'll get the aem kit.
