Spartan questions
I recently put my DPF/CAT delete pipe in & got my tunes & headed out for NY from TN. On my trip I encountered a few things that I have questions about.
First off I was pulling a 16' box trailer weighing roughly 5000lbs with the DD set on the 150 tune. 1. At w.o.t it would blow a little white smoke out! Why ??? what is going on it only has 3200miles on it. When my Duramax did this it meant it was time for injectors.. 2. Were on the DD gauge cluster is a good egt reading? I cant find a EGT reading...Nor can I set a limit for it. 3. If you leave your DD on for a couple of hours with the truck off, do your gauges freeze up?? |
ive had a couple calls on this white smoke you are refferring to, im having trouble getting the 2 ive been dealing with to duplicate the smoke when driving, im curious as to what you come up with as well, have you tried to contact matt at spartan
To read the correct EGT temps you will want to look for EGRTA (Exhaust Gas Recirculation Temperature Sensor A (EGRT/EGRT-A).
Of course this is considering you have have changed to the 261 FORD specific parameters on the DD. If I leave my DD on for 10-15mins after I shut the truck off, it will freeze up too. I just unplug and plug, simple as that. |
Just wanted to add that my DashDAQ (non Spartan) would lock up also. Ever since I downloaded the new updates from DrewTech, it no longer locks up. I believe it is version 1.4
re-wire dashdaq
my dd froze constantly, and i hated it staying on while the truck was not. Opened up the OBDII harness from the dd and found the orange wire. cut this wire and connect the side coming from the dd to keyed ignition........soooo much better.
You cut a wire coming off your OBD-II port? I guess I see what you did with the the DD, but what happens with the dealer or any other shop has to hook up to it?
That makes the ODBII port hot only with the key on. And that should be fine, as diagnostics only work with the key on anyhow. |
Ah I see.......but still
Dont know it's only a week old.... Im trying to get a hold of Matt as we speek.
