DPF removal disaster
So tonight while doing the DPF and exhaust install we ran in to a snag. There are 4 sensors for the cat and dpf delete, 3 are those screw in things and the 4th has the rubber tube. Well the plastic piece from the bracket that goes in to one end of the rubber tube snapped. This bracket also has the electrical connector attached to it, i hope you guys know the part i am talking about, i will try and get a pic tomorrow. Anyway what would be the best way to order this part without going to the dealer as i am heading to NY and would like to have this when i get back so i can finish it asap.
Jonathan |
ok that is great thanks, i do not feel like such a moron now. everyone said how easy this dpf removal was, well i swear it is not that easy at all
Also does the cat / dpt delete pipe mount to anything as the OEM hangers are removed when you take of the cat and dpf or does it just wait until the exhaust hanger
The pipe does not mount to the hangers, just bolts up to the exhaust.
ok i am instaling a MBRP exhaust also. I just want to make this clear before i start the install.
The cat delete pipe does not have any hangers at all, and the MBRP exhaust eliminates a few of the hangers too. So from when then Delete pipe is bolted on the next hanger is back at the rear axle where the MBRP bends to go to the tail pipe. Is that not a lot of weight for there to be no supports for that kind of span or am i missing something here. Jonathan |
It will be fine and is only a fraction of the weight of the dpf and cat. Is your truck lifted? If not, your may have to jack up the rear or drop the the spare tire and heat shield to install the exhaust.
I actually removed the stock hangers from the truck, theres like 3 small 13mm nuts on the outside of the frame rail holding the hangers on.
I also had to order a new black box mine was broke before I did the full delete. My ford parts guy had to email ford to find out what the part# was b/c his computer didn't even show the part existed. We found the part only by going on the diesel techs computer which has different software which is stupid but we get the part number and we can't order it b/c the part# doesn't exist. so the last I heard from my friend that ford email him back and I got one coming.
I have an extra one that i could part with. the ford part number is 8c3z-9j460-b you can also get it in a motorcraft cheaper that part # is DPFE-9 (go figure).
o ya the new sensor will come with the bracket and new hose |
