Spartans Delete Pipe?
Has anyone here tried their delete pipe yet? If so, what do you think? Any pics you can share?
Thanks, Jason |
ive got the spartan cat/dpf delete pipe, went in pretty smooth other than my own problems and where the delivery jackasses banged it around, and also have mbrp exhuast and that was pretty smooth too
only thing i dont like about it is that the delete pipe only has one hanger, at the downpipe connection, then the next time it catches a hanger is with the mbrp exhuast |
hmm, so you dont have the full delete pipe from downpipe all the way out the back?
i thought it was a complete system? did you go with or w/o muffler? i am running sct's delete and it has the same hangers. 1 near downpipe and 1 where the mbrp goes over the axle. isnt that the only factory locations? how do you like the sound? |
yes i have a full cat/dpf/muffler delete, a full straight pipe from the dp back
i like the sound, not like the 6.0 but i like it a little better |
I am running the Spartan (Flo-Pro) 4" downpipe-back exhaust with no muffler. The cat/dpf delete section of the exhaust has a hangar on the forward end near the downpipe and a second hangar at the rear of the dpf delete section. All OEM hangars were used when installing the system (delete areas as well as tail pipe areas). Think 4 or 5 hangars total....
you like the sound better than the 6.0 or it sounds a little better than it did before you did the delete?
its sounds alot better than stock and imo its a little better than the 6.0
Do you have any pics?
ill see what i can do after work today, ill have to find a camera from someone, i aint got one
