Injectors question - Ford Powerstroke Diesel Forum
Old 09-18-2008, 07:46 PM
Project Abused
Question Injectors question
So im on the edge of buying new injectors for the truck, and was brushing up on the details. The company who sells the injectors does not sell the High Pressure Fuel Tubes, I was wondering for those who have replaced the injectors if they had reused the old tubes, even though it says to never reuse the tubes after being loosened. (tubes I am refering to is the L&R Fuel Rail banks, to the injectors.)
Old 09-19-2008, 06:29 AM
Do not, do not, do not, DO NOT even think of reusing the old tubes, period. You will be installing a new engine within 1000 miles.
The new tubes come with the Ford o-ring pack. Just head down to the dealer and buy 8 packs; I think they run about 16 dollars per pack.
Old 09-19-2008, 11:01 AM
Project Abused
Thats what I figured after the warning in my 6.4 book
Old 09-19-2008, 11:03 AM
Ole White
What size injectors are you going with??
Old 09-19-2008, 11:19 AM
Let's Run'em
Hey Matt how hard are they to install? I know you have them in your truck, but whats been holding me back is the fact that I'm not sure if the cab has to come off....thanks!
Old 09-19-2008, 12:39 PM
Most definitely do not want to compromise any part of the fuel injection system as your talking about some super high pressures in the rails and related hardware. My bro has had a couple DMaxs and one blew a small hole in one of the high pressure tubes (some kind of weird iconel metal or something) and the whole engine compartment was covered in diesel. Tech said it could cut stuff about like a plasma cutter at such high pressure. Seems like I remember a number mentioned in the 21-25,000 psi range???
Stay Tuned
Amp
Old 09-19-2008, 01:57 PM
Project Abused
I heard the cab does not need to come off to install the injectors.
Goinging with the 110 up from elite diesel
Yea that's a lot of pressure I have seen a hp air leak on the Kennedy cut a mop handle in half and damn near make you deaf even with double hearing protection.
Old 09-19-2008, 02:12 PM
Let's Run'em
Well thats good to hear.......I expect a full write up so I can cheat and no go through the same headaches and pains that your going to go through
Old 09-19-2008, 05:28 PM
Indeed....I am VERY curious to see this done with the cab on.....now only if I coule change the low pressure turbo without taking the cab off...lol
Old 09-19-2008, 06:19 PM
Project Abused
Its just what I heard, not 100% I do know some guys prefer to take the cab off as its easy to work around but sometimes its not possible.
