dpf delete pipes
where's the best place to get dpf delete pipes ? Is it best to remove the dpf or the dpf and converter. does anybody know the cost
Do a Google search for DPF delete and you'll find lots of options.
From what I have seen, because I have personally been debating this for over a year, The cost far exceeds the outcome. If your looking for better MPG, your not going to gain much. Maybe 1 or 2 MPG. If your looking for power, there are lots of less expensive ways, that are LEGAL. When you delete the DPF you will lose your warranty, and risk getting fined if the DOT catches you, and it actually costs more than a good tuner that keeps the DPF intact. |
you can get alot better mpg than 1 to 2 mpg gain more like 5 to 6 mpg. get some ones opinion that has it done not someone who just reads about it. i just drive 2600 miles to cali and back and hand calculated the worst mpg i got was 16.2 pulling 7k unloaded i got 19.1 and this is in a 4wd one ton
dpf delete
what system do you haveon your truck ?
Is it just your dpf deleted or converter and dpf.
i just did mine about a month ago. the tuner from spartan is 1100. that's the tree tunes and the tuner. i bought my pipe from powerstroker67. search the members on here and you'll find him. he builds a pipe that is really good. it went right in with no troubles. it was 370 shipped.
he has all options you might want. you can use the stock back half or a 4 or 5 aftermarket. just let him know and he'll send it out. as far as deleteing the cat, the pipe is the same cost but if you leave the cat in you'll need to replace the gasket between the cat and dpf which is another cost. when i checked it was 130 because the dealer only sold a kit tha had all the nuts and everything. i would go with the cat and dpf delete, it's easier and cheaper and you'll theoretically get better milage out of it. the only reason i would leave the cat in there is you might have a better chance at passing a visual inspection. i doubt you would though. |
I get 13.5 around town and 17 to 18 on the open road with DPF intact. I am still debating the issue for myself. I haven't ruled out the possibility of deleting the DPF, I just don't want to regret doing it. And if I can't gain enough MPG to make the switch pay for itself in a years time, I don't think it's worth it. $600 - $800 for the DPF removal system would take a significant improvement in MPG to be justified. I'm not yet convinced. |
by the way i have seen better than 1 to 2 gain as well. i went to idaho without it and never saw netter than 16 on the freeway, i averaged 20.5 last trip. 2 weeks ago i went to san diego, last time without it i averaged 18 going and 16 coming home, with it i was at 23.5 going and around 21.5 coming home. that is at 70 mph. there are other tuners that give you power with the dpf, spartan has dpf friendly tunes as well but i disagree that you'll only see 1 or 2 in gains with the dpf. i don't know anything about the sct, which is the other dpf delete tuner, because i never have had one but i think they get about the same milage out of them. the majority od the cost of the spartan tuner is due to the dash daq. it is a good piece. in my opinion you get way more for the 1000 or so dollars. you can see the demo of the dash daq at drewtech.com.
the 1500 is well worth it in my opinion. and yes his gains were significant, i used to get 9 miles to the gallon pulling 7000 lbs. thats a 6 to 7 gain. that tuner will pay for itself in a year at that rate Last edited by DKR; 09-15-2008 at 05:45 PM. |
That sounds great. I'm not in a hurry. I figure the longer I wait , the better this stuff will get.
There is a huge diff in a 3/4 and a 1 ton. I have two brand new 08's one 3/4 and one 1ton. You must not be a highway driver or do road trips very much becuase going from 12mpg to 16mpg is a huge gain. I have the sct livewire system full 4'' turbo back exhaust. If i had to do it all over agin i would go with spartan not sct.
