Fuel pressure gauge - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-19-2013, 11:57 AM Thread Starter
Fuel pressure gauge
Where would I put the sending unit for a fuel pressure gauge. Not rail but just fuel? Is there a port on the bowl like the 6.0 or what? And do I need a separate fitting for the fuel like on the 6.0?
Thanks for the help!
2008 ccsb F250 lariat
SCT tuned by Gearhead Single 371, MPD CCV RCD pushrods ARPS
SOLD!
2003 f250 4x4 crewcab lariat (03 Turbo)
Perfomance:
ARPs, 175/75 Industrial Injection, EGR delete, 5" MBRP,6.4 Banjo Bolts, Coolant filter SCT Innovative Xtreme X, PHP FICM tuner, AirDogII with Sump
2.5" level, 18" monsters with 33/13.00/18 Nitto Terra Grapplers
powerstroke 825 is offline
post #2 of 2 Old 12-22-2013, 07:39 PM
B585Ford's Avatar
There is a Schrader valve if you are wanting to monitor the pressure the LPFP is putting out...or you could T into the line after the pump.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
