Question about trip to dealer and mini maxx - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 18 Old 12-16-2013, 07:59 PM Thread Starter
Hi all...
I just installed some hids into a set of recon lights. The drl cuts power to the lights and they flicker even with a relay. I need the drl turned off by the dealer but it can only be done through programming. I'm worried they will mess up my mini maxx programming.
Guys would you mind sharing your thoughts on this?
Ps... Here's a pic of my ride
gwilkrrs likes this.
roccos_van is offline
post #2 of 18 Old 12-16-2013, 08:15 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 9 Post(s)
Feedback Score: 12 reviews
Sounds like a bad ground on your hid relay or something of that sort
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #3 of 18 Old 12-16-2013, 08:26 PM Thread Starter
Its not that. The lights work perfect when in the on position... But the relay makes a loud buzzing when they are off because of the daylight.
post #4 of 18 Old 12-16-2013, 08:47 PM
WoodBoy's Avatar
Usually kits tell you that they are not DRL compatible. You will need to return your truck to stock (programming at least) before they perform something like that.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 18 Old 12-16-2013, 09:16 PM Thread Starter
Crap I was afraid of that. If I put the stock programming back it won't run...(dpf and egr deleted)
post #6 of 18 Old 12-16-2013, 09:49 PM
WoodBoy's Avatar
If you know the dealer well enough you could pull it in the shop and let it return to stock in there. Let them do their thing, reprogram and be on your way
WoodBoy is offline
post #7 of 18 Old 12-17-2013, 06:37 PM Thread Starter
Update for anyone who cares... I just told them not to do any updates and they went in and turned off the drl and plugged the mini maxx back in and everything was fine. If they ever cause a problem... It's an easy fix... Have ford load the stock programming back... Then reinstall h&s program on the spot.
post #8 of 18 Old 12-18-2013, 01:02 AM
srjd's Avatar
Quoted: 2 Post(s)
So if ford changes the programming to turn day time running lights off. Then you put the minimax back on that doesn't overwrite what they did. Did you return the mini back to stock or just leave it programmed and let ford do there thing. I need to do this. What did they charge you
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #9 of 18 Old 12-18-2013, 03:52 PM Thread Starter
No...they unplug the mm from the obdii port...then program the lights...then plug the mm back in and done. As long as they don't do any engine software updates you're fine.
post #10 of 18 Old 12-19-2013, 05:40 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
he is right, you can turn that stuff on and off with tune loaded. I turned the lamp outage feature off and ran 4x4 self tests today on my 6.4 while it was still tuned. everything went fine.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
