Gauge sensors (trans, boost, get) - Ford Powerstroke Diesel Forum
post #1 of 26 Old 12-16-2013, 06:19 PM Thread Starter
TwinTurbo6.4's Avatar
Quoted: 82 Post(s)
I'm looking at getting a set of gauges for my 6.4 for a more accurate reading for monitoring. I already have what I want picked out. 60 psi boost, 1500 egt's, and 300 trans temp. I was curious as to where everyone is putting the trans and boost sensors. Any advice would be appreciated as well. Thanks in advanced.
'08 F250
H&S Mini Maxx w/ Cale Thompson tunes, FloPro 5"/EGR Delete/Cold Side Pipe, Pillar Gauges and CTS2,
Gear Alloy Big Blocks 20x12 -44, RetroFit Headlights - Morimoto Mini H1's
TwinTurbo6.4 is offline
post #2 of 26 Old 12-16-2013, 06:32 PM
BK1977's Avatar
For about the same price as 3 good gauges you could get an edge insight cts which will monitor way more and read and clear trouble codes. Also it plugs into the obd2 port so no splicing or manifold tapping. Ivebeen very happy with mine
Sent from AutoGuide.com App
03 f-250 CCLB FX4 6.0. H-11 studs, egr delete, swamps 58 v ficm, sct sf3, autometer ultralight boost, pyro and trans temp. Complete 08 bed. And a few other things
BK1977 is offline
post #3 of 26 Old 12-16-2013, 06:38 PM Thread Starter
Quoted: 82 Post(s)
I looked into the insight and my friend showed me him gauges com paired to the in site and it was quite a bit off. Plus I am looking into getting the Spartan tuner as soon as the warranty is up.
'08 F250
post #4 of 26 Old 12-16-2013, 06:51 PM
Rocweiller's Avatar
Quoted: 2 Post(s)
Spartan has gauges in the unit.
2008 F250 XLT SBCC grey flake, 33x12.50 Toyo m/t's on 18 inch mammoth wheels. Rhino lined go rhino nerf bars. S&B cai,Spartan tuned and straight piped. Fake *** chrome grille removed and a matching colored grille put in place.
Rocweiller is offline
post #5 of 26 Old 12-16-2013, 06:58 PM Thread Starter
Quoted: 82 Post(s)
Nor do I have 1400 doll hairs to fork over.
'08 F250
post #6 of 26 Old 12-16-2013, 08:51 PM
Rocweiller's Avatar
Quoted: 2 Post(s)
1499. Well you said you were wanting the spartan anyways. Why pay extra for gauges if your wanting to get the tuner with capabilities? H&s isn't any cheaper. I guess you could get a scan gauge for 200 or less, but still not the same as gauges in pillar etc.
post #7 of 26 Old 12-16-2013, 09:00 PM
Rocweiller's Avatar
Quoted: 2 Post(s)
If you prefer the mechanical gauges I had my 6.0's in an a-pillar and the tranny sensor went into the tranny through a spare bolt hole for lack of a better way to say it. Boost I drilled and tapped into an elbow toward the front of the motor. Egt's drilled and tapped into the exhaust before the turbo down under the truck. If your stock no rush on gauges in my opinion.
post #8 of 26 Old 12-16-2013, 09:05 PM
Rocweiller's Avatar
Quoted: 2 Post(s)
Gauge Installations at DieselManor - 2008-2010 6.4L Ford Powerstroke
post #9 of 26 Old 12-17-2013, 09:29 AM
08stroker250's Avatar
If you do go mechanical, I would get a 1800 or 2000 degree EGT gauge. Not that you'll ever see that high, but you'll have the potential to see over 1500 once tuned.
My advice is to save the money though and put it toward the tuner down the road. You're going to have a decent amout of money and time in mechanical gauges once they're installed.
Jeff Dodd
2012 Ford F-250 Lariat CC/SB
Mods - Spartan tuned via laptop, 4" AFE stainless exhaust system, 2.5" PMF BMC leveling spacers, 3" PMF lift blocks, Fox Racing 2.0 shocks, Recon smoked mirror & cab lights
08stroker250 is offline
post #10 of 26 Old 12-17-2013, 03:15 PM
Seems like a waste to get gauges when you can read everything from the OBDII
jgos929 is offline
